Hello all,
I am in the process of adding a steaming light to the front of my mast, swapping out the anchor light with an LED light, and replacing the old Shakespeare antenna with a Metz version. All of this is on the hard with the mast on sawhorses.
Mast is 29'10" high. Aluminum Zspar (see photo)
Mast base was sent to RigRite in RI and yes it came back repaired thanks to the lovely Megan there who tracked it down and saw it finished and back to me. Yea for Megan.
I put in another conduit by putting a slot down a 3/4" Sched 200 irrigation pipe and pushing it up the inside of the mast on the conduit guide. Pretty closely matches the other conduit that's there. This mast seemed to have to "guides" for 2 conduits so I copied the existing one.
OK I've pulled new wires for the 3 components..... Ancor 16-2 for led anchor light, 16-3 for steaming/deck combo light, and RG-8x for VHF. These will go to through deck connectors located directly in front of mast and then wired to switch panel inside cabin. I am using Ancor heat shrink crimp connectors with the Ancor ratchet crimper. Tried to solder as a test the Pl-259 and quickly realized that it's beyond me. (Thanks Maine sail for your tutorial) The Ancor crimper was within my budget and this is not an around the world odyssey craft but a Barnegat bay day sailor.
Now the questions.
1. When I make the connection for the led wires at the top of the mast do I just let the wires hang down the conduit and is the weight of the hanging wires down the conduit going to over time pull the connections apart by fatiguing them. I saw Maine Sails tests and see the strength of the connections (if done correctly) but do they hold long term with the weight of the wires on them???? I dont see any way to "take the weight" off the connectors by "securing" the wires before they enter the conduit on the way down to the mast base and the deck. Perhaps this is a nonexistent issue. Ok if I'm overworrying. Just tell me so and I'll let it go.
2. There is a slot on the front of the mast towards the top (see pic) that I have no idea what it's pupose is.
3. There is a sheave on the mast base that is at directly at a right angle to the mast that I have no idea what it's purpose is (see pic) The white sheaves are for the Main sail halyards, primary and spare, obviously, there's a matching pair on the other side of the mast base. These are the new ones replaced by Rig Rite. they lead aft to cockpit. The black sheave leads to the middle of the side of the boat.
4. I am planning to use 1/4 in. X 5/8 in. aluminum rivets to secure the mast base to the mast. ( see pic) Mast base is aluminum as well as the mast stem. Anyone see a prob. with this???
5. I wish to place a small pennant line on the spreader. I dream of hoisting a pirate flag someday as I conquer vessels crewed by scurvy dogs and steal their rum, booty, and pretty wenches. Ok just rambling. Seriously anyone have a suggestion for the best way to secure a small sheave to the bottom the spreader??? no pic of the spreader but it's aluminum too.
As I've said before this is the greatest site on the web and I love the comradeship and friendliness that is here. Without all the great help everyone provides I wouldn't have been able or willing to attack these projects. Thanks for everything.
John
Now the questions.
John
