How to get to the fuel tank sending unit ?
52
Catalina 310 Gloucester Point, Va
OK...oil in bilge,traced it to a leak around the gasket around the fuel tank sending unit. But how is the best way to get to it to replace the gasket? I have a A/C unit so the door to the aft compartment is not available,
I can take off the wood panel (near the hot water heater)..but i can't reach back far enough...seems only way is to go Down head first in the aft starboard or port locker put probably need someone to pull me out. Anyone
Have any good tips to gain access to the fuel tank area ? I can't imagine what you would have to do to replace the fuel tank itself !
Thanks
Bob
Dec 25, 2008
1,580
catalina 310 Elk River
You will need to remove the AC unit. Why is it there anyway, is it a window unit?
My Cruise Air unit, is in the outer forward section of the port cockpit locker with the return plenum facing down into the aft berth below it.
Mar 15, 2011
52
When I open the door astern in the aft cabin (port side)..that is where the back of the A/C filter is..pretty
Much takes up the whole inside of the door...almost want to go head first down the cockpit locker on the port side, or even the starboard side....
Bob
11,722
First try tightening the sending unit bolts slightly. This can often stop the gasket from leaking without full removal of the sender..
Mar 15, 2011
52
MaineSail...yes, that was/is my plan, the problem is getting close to them is the issue, I am now thinking about getting one of those screwdrivers that is about a foot long, and going down via the starboard deck hatch and see if I can reach them.
Bob
Jun 30, 2010
40
Catalina 310 Bristol RI
Bob,
I believe you need a special torque wrench, T20, to remove the sending unit.
When I had a fuel problem, a mechanic removed the sending unit to check the fuel, and he needed a "T20" torque wrench.
Kevin
Dec 25, 2008
1,580
The sending unit has very little head room above it and you will need a #2 stubby philips to get at them.
Mar 15, 2011
52
Plenty of room above tank sending unit..if I go down the stdb deck hatch and someone holds my legs to pull me out I think I can try to tighten the bolts holding the sending unit &gasket..and hopefully stop the weeping going into my bilge
Bob
Dec 25, 2008
1,580
You certainly can get there from being a contortionist from the cockpit hatch, but if it is like mine, you will need a stubby screw driver to get to the rear screws of the sending unit.
paulj
Mar 16, 2007
1,361
Catalina 310 Anacortes,Wa
bobgelb@gmail.comm
Looks like you need a inspection port or an access hatch back in that area....use the money for the aux fuel shutoff valve to buy an inspection or emergency fuel shutoff access port.
During an inspection of my steering seal I found a problem with the steering cable.....good thing I have good access back there.
Just some thoughts
paulj :troll:
16
Catalina C310 Dana Point, CA
Fuel Tank Access and Cable Guard
Thanks
Bob
Bob,
I just wanted to share a caution! It does appear that the easiest way to your fuel tank sender is "down from the top", from one of the two cockpit access hatches (most likely starboard). If you do that, have someone there with you--I say this from experience. One day I thought it time to check the hose clamps on the exhaust hose and worked my way down, and down, and down. Tightened clamps, and then tried to back out. Took quite a bit of doing and for awhile I thought it wasn't going to happen. I was eventually able to back out but swore I'd never, ever, do that again--at least not when alone. That hatch size is deceiving and I was so glad to not be stuck there, up-side-down, for days!:dance:
Paul J,
At commissioning, when the boat was new, I noticed the steering stop cable was precariously close to that fuel valve--dealer subsequently installed a wood block (see photo) to do what your fix does--keep the cable away. I was concerned the cable would get locked around the valve and then rip it out, spewing fuel in the bilge--wouldn't be fun. The fix has worked and I've not had any problem. C310 Owners reading this should take a look and take preventative measures accordingly.
Happy Sailing,
Gary
1,944
Catalina 310 #185 Quantico
Access
I regularly climb down into that space to do work by just going feet first through the port locker, stepping on the shelf over the holding tank and then down into that bilge. I don't think I qualify as a little guy at 5'9 and 190, I'm just saying ...
Dec 25, 2008
1,580
Happy Sailing,
Gary[/quote]
That's good stuff Gary, I have always been concerned about that interference.
Mar 15, 2011
52
So Cal Gary.....going down the starboard hatch head first, I also realize that I better have someone there behind me to pull me out. ..thanks forth tip
Bob
Sep 29, 2008
1,944
Question for Stu
Since I know Stu follows this forum, I thought I would ask him to look at PaulJ's pictures and see if he could tell us which fitting would have the screen that is discussed in the other thread as PaulJ was nice enough to post pictures. That was on my spring commissioning list that just got lost in the other higher priority things (engine is running great).
Ray, can you give me a more specific link or direction to the particular picture you are referring to, so I can help out?
Sep 29, 2008
1,944
A or B
Here is a follow up for Stu. I am thinking the filter/screen should be on A or B. Your thoughts?
Ray, sorry I'm not that familiar with the "stuff" back there on your boats. The screen is at the end of the pickup hose that is the diesel fuel supply to the engine, which goes tank, primary filter, fuel pump, engine. You have to remove that hose from the inside of the tank to see what is at the end of it. Our reports are that Catalina continued putting them in until 1994.
Sep 29, 2008
1,944
Thanks Stu
I will check it out next time I get to my boat and post here what I find.
