O'day 23 swing board stuck hard
277
Hunter 22 Fin Keel Lake Martin
Just did a search and it looks like the 23s had a 6" plastic pin? How wide is your keel around the pivot point? Have you been in touch with Rudy at drmarine.com?
Keel is 6" wide at the Pin.
No I haven't contacted Rudy I think I'm just going to replace the pin with a stainless steel bolt and call it a day.
I need to get this boat in the water before I go insane.
It's already taken me way longer than I expected to rebuild the center board and shape it.
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
I don't blame you Bill for wanting to use your boat. The bolt should work. A friend of mine had to replace the pin on his Tanzer 22 keel and he used a stainless steel bolt. His centerboard was made of cast iron and he got it to work.
Jun 14, 2011
277
Ok.
Talked to Rudy while I had him on the phone about another issue. On the cast iron keels of that year the pin is driven in and out. There is not plate and wedge setup.
Stainless bolt is gonna work just fine :-D
Thanks for the help guys!
Jan 24, 2005
4,881
Ok.
I learn something new every day Bill. Thanks for the info.
Jun 14, 2011
277
I live by the motto "if your not learning your not living"
I have a crap load of living to do when it comes to sailing!
Thank you for all the help!
Jan 27, 2010
143
Oday 1971 23' Oday Pop Top Yet to be determined...
Interesting! So some of the cast iron keels have "pins/bolts" some have the wedge/pin style? Good to know!
Jun 14, 2011
277
Stock there is no bolt involved. Just a press fit fiber pin.
Mine will have a very large stainless steel bolt as a replacement. Not as hydrodynamic but I'll survive.
