Backing plates
Smitty
Sep 16, 2005
108
Cal 28-2 Milford, CT
My Cal 28 does not have backing plates in some places that really need them. So, where/how can I get or have made backing plates for things like stanchions and cleats.
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
Make them yourself out of Starboard material or go to a steel/welding shop and see if they have some stainless or aluminum....I walked into my neighbors steel shop and found some nice stainless about 3" wide and replaced all the weeny washers Oday used for backing plates, there were areas that couldn't get the stainless plates so I used thick fender washers
464
Catalina 30 MKIII Varuna Boat Club
I went to my local auto parts store and picked up a few sheets of 3/16" diamond plate aluminum....cut them to size, drilled holes and mounted them under my cleats. Only because of my allegedly anal tendancies, I also added large stainless washers under the nuts to avoind any "pull-thru". Even for me, more than that is overkill. Good Luck and Happy Sailing.
Pearson 26W Marblehead
Ive used 3/8 inch exterior grade plywood and stainless washers. Easy to find Easy to work with no trouble or failures
Oct 2, 2008
3,815
Pearson/ 530 Strafford, NH
Hi Smitty,
I got some aluminum at Lowe's, cut it to size, and drilled it out matching the cleat while it was off. I then held the plate in place with the bolts while I added Gorilla tape to remove the bolts and add G-Flex epoxy. I did this to get a flatter surface for the backer and reduce the size of the holes since there was some elongation. The tape covered the entire plate and tightly around the sides to keep the epoxy in.
After it hardened overnight, I removed the tape (mostly) and using the cleat as a guide to drill straight down from the top. I was able to hit the holes perfectly. Then I used a countersink to taper the hole.
Using Butyl tape around the bolts and on the bottom of the cleat I snugged them down tight. Here's a pic.
All U Get
Phil Herring
Alien
Mar 25, 1997
4,924
- - Bainbridge Island
I don't know the Cal 28, but one of the popular production boat tricks is to embed aluminum backing plates in the glass, then use tapping screws to embed hardware. It looks like there are no backing plates, but they're inside.
I'm not saying this is the case on your boat, but I recommend checking first.
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
Phil is right in noting that some boats -- like my H28.5 -- have aluminum backing plates installed in the fiberglass where additional winches are often installed. I found this out when drilling through the fiberglass to install some horn cleats -- and saw that the drill was bringing up bits of aluminum so I didn't need the backing plates I had already fabricated.
BrianW
Jan 7, 2005
843
Hunter 26 Guntersville Lake, (AL)
Are there any ways to non-destructively detect the presence and "footprint" of embedded aluminum plates? BrianW
Mar 6, 2008
1,530
Brian - here is the simplest way to test if there is already a backing plate. Remove the parts that is screwed on to the deck. Place the screws back in the holes and make a continuity test from one screw to the other. Or measure the resistance. A very low resistance indicates a backing plate. You can also look at the threading of the screw. If it is a machine thread screw then you know that there is a backing plate. Use a magnet on the deck - it the embedded material is steel then the magnet will be attracted. If it aluminum the magnet will not be attracted.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
if you have a stud finder that detects metal that will work too.....
regards
woody
BrianW
Jan 7, 2005
843
JoeWhite, Brad, and Woody.... Thanks, for some excellent suggestions! I have 3 good alternatives. Since I already have a stud finder, I'll try it first. After a little research, I see they work from the principle of sensing material density differences. I bet that will work to define both the presence and outline of an embedded aluminum plate. Thanks again. BrianW
