black spots on nonskid
Oday 26 Alberta
Hi I have black spots on the deck of my Oday 26. Getting them off the nonskid is possing a problem. I used mequires oxidation remover on the rest of the deck and it works fine. The problem is getting them off the nonskid. I spent about 8 hrs and only have 1/4 of the deck done. Has anyone had this problem and found a product or method that works. Thanks Bill
2
Oday 26 Niantic
I am a 26 owner also but the boat make and model does not matter. Same thing occurred on a 23 that I used to own. I have used Tilex to remove the black spots off of my non-skid and for the more stubborn spots Soft Scrub with bleach.
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
I would be very careful with deck cleaners guys. I used a cleaner years ago that contained Oxalic acid and it literally ate out the caulking under my gunwale strip. After that, I had leaks coming into the cabin up the ying yang. The caulking under this molding is only good for about 10 years, but if you need to recaulk the molding you need to remove it and it's easier to do that job on the hard.
After that episode I stopped using deck cleaners and went back to soap and water. With that said though, some of the guys on this forum have used Mr. Clean Magic erasers with good results. I've also tried it inside my cockpit but I'm still leery of using something that can cause leaks later on down the road.
Dec 26, 2009
211
Oday 22 cleveland
Hey! I'm finally in the water!!!
I use the magic sponges last lear and did the same this year.
I have a pesky oak tree out back that really make a mess. The sponges do the trick but they do contain a super fine abrasive, use them on non-shiny surfaces and you're good to go.
Jan 24, 2005
4,881
Hey that's great Kevin! You're probably in at the best time. The weather hasn't really been all that great up to now. Have a great season!
Dec 26, 2009
211
Oday 22 cleveland
Hey Joe, Check this out, you know I'm docked at Edgewater inside the breakwall of Cleveland. Last year my depth guage (at dock), read 8.5 ft, the water is a bit higher this year at 10.5ft. I now have to step- up - onto my boat!
Dec 26, 2009
211
Oday 22 cleveland
24"
992
Oday 25 Gibraltar
Same thing here at Gibraltar at the mouth of the Detroit River.
Rich
Jan 24, 2005
4,881
You guys got a lot of water on those lakes this past spring. We went through that same scenario a couple of years ago right here in my city, Taunton Ma., and we go National news coverage. Old mill dams in our city were threatening to wash away and flood the city. I lucked out. I only had 6" of water down my cellar. My neighbor who lives on the water across the street from me had 4.5' of water in her cellar. I was able to paddle my kayak right into my neighbor's back yard. :eek:
Jan 24, 2005
4,881
crap. My lake is down 50%... crap.
It really depends on the streams that flow into your lake Gabe. we have more that one river that flows into our lake from several towns to the North. Then our lake flows into some river's that flow into the Taunton River which is connected to Mount Hope and Narragansett Bays. The Taunton River also has tides which can constrict the flow of the rivers leading out of the lake and cause high water in the lake. It really has a lot to do with the dams and how they are controlled too.
