Hi,
I have a boat with no sail rigging at all. Found a very good deal on a mast that is the same length as the original. The boom is longer, by about 3' or so. Probably because the boat it was designed for was 4' longer than mine.
Is it reasonable to think I could cut the boom down and make it fit? I think I have the original boom so maybe it could be used? Not sure how much of this stuff is generic. Is it at least reasonable to assume I could adapt this mast to my boat? Totally new to sailing and starting with a fix it up boat. $$ always important.
added info:
I have the orginal specs on the boat. I 28.6' , J 7.8, P 26.3, and E is 10.3
The boat was recovered from flood damage and was rolled over on its mast. I have the sails which are well used and will have to be replaced as well. I have "a" boom but not sure it is the original so I might be wrong about the comparison made above. Seems a lot of stuff got mixed up in the yard during clean up. The mast I found says it is almost new. Mast, spreaders, boom, haylards and stays.
Mast is 28' tall, 5" by 3 and 3/4 with a 12' 6 boom. Not sure again how well this stuff swaps around. I would like to keep the boat as close to original as possible but a new rig with all the gear was over $5000 from US Spar. This one is $1700 and same brand. I have only been looking for a few days and this is probably not the only deal that will come along but does look like a good match for a reasonable price. I appreciate the feedback. I have already learned a lot and realize I have a ways to go as well.
added info:
