Minimal Bottom Repair
geehaw
May 15, 2010
231
O-day 25 shoal keel Valdez
Well I got the bottom of the boat sanded ready for new paint except ran into a few a problems. Now I am asking this because I am over budget on the boat currently out of work and getting paints epoxies is all but impossible where I am at and very expensive. Cost over $80 to get 2 gallons of bottom paint to me. I only found 2 willing to even think about shipping it to me. One place from somewhere back east tried, it made it to Chicago and then was sent back to sender. I have a feeling the other place sent it illegally but at least I got it.
Well back to my question So I sanded through the gel coat in a few areas and have 2 gouges from a rock that jumped out in front of me last year. And I have 2 areas under each front bunk that looked likes maybe had rocks between the boat and the bunks. Each side has about a quarter size hole and one side an additional few dime size holes and areas that look like someone beat on it with a ball-peen hammer.
Now I know I should fill everything with epoxy and then barrier paint the whole bottom. But I already have 3m Marine polyester filler for above and below water line. So I want to use that and and just buy a half gallon of barrier paint to paint over these problem areas. and then anti fouling ablative. So in all your opinions will this suffice for a year or two?
Not planing on leaving it in the water this year. Will put it in and take it out each use. To many scratches from the harbor people moving it around and having to find it every time I went down there. and have to climb across 3 or 4 other boats to get to mine. oh sorry blowing steam. Well so opinions please thanks in advance our snow almost gone and wish it was in the water already Greg
Nov 9, 2008
1,338
Geehaw,
I can't help you with the mechanics, but have you tried Wholesale Marine? I bought bottom paint for $30 less than locally, $50 less than Worst Marine, and shipping was free. But, I don't know where Valdez is.
Jun 2, 2004
5,802
You are in Alaska, right? And I think there is at least one West Marine store so why the trouble getting paint? If you are sailing off the trailer then barrier-coat and anti-fouling should be secondary. You want to spend your money on making sure the "holes" are fixed. The 3M filler should work well for that.
Mar 8, 2011
296
Ranger 33 Norfolk
I've never used more than straight epoxy to cover over areas devoid of gelcoat. . .I figure it is better than having raw fiberglass exposed to the water :doh:
I'd fill your gouges with polyester putty, then paint over them with a straight coat of epoxy, then scuff and paint your anti-fouling. . .then go sailing
Just my 2 cents, and remember what you paid for it :D
Jun 1, 2004
8,323
I think you're fine..... but you need to find a better source. There's a west marine in anchorage, call them and ask how much to deliver. But what about Port Valdez Marine & Outdoors? 129 Egan Dr, Valdez, AK (907) 835-2628 ‎
geehaw
May 15, 2010
231
No one ships
The place you mention Joe Is not much more then a hardware store. Not really set up to send anywhere . I have been in contact with west marine and they will not send to me. I am in Fairbanks 360 miles from either place. Well I am now going to cover with gel-coat ad bottom paint and call it done!!! Thanjs all for your responses.
Jun 1, 2004
8,323
That sucks.... but I think you'll be fine with whatever you do. Just go sailing.
Ross
Jun 15, 2004
14,693
My 1968 boat has no epoxy repairs on the outside but has many polyester repairs on the outside. It has some epoxy barrier coat and some bottom paint and is doing fine. I really wouldn't trouble myself about what is used as long as it is as good as was used to build the boat.
