Although the Universal manual says that the M25XPB is self-bleeding that isn't necessarily so. So after replacing the filter, I unscrewed the bleed bolt on the housing and then went to the Racor Filter and unscrewed the primer pump and pumped until I started seeing fuel. Then I closed that bolt and opened the bleed bolt on the secondary fuel pump that is mechanically attached to the engine and cranked the engine until fuel came out. Closed the bold and fired the engine up.
PaulJ, Pictures with labels are attached.
