Adjusting Voltage Meter
1,981
Catalina 310 #185 Quantico
My meter is reading at 15volts, but when I put my digital meter on it, I get 14.5volts. I suspect there is an adjustment I could make to the meter if I open the engine control panel. Has anyone tried this?
7,751
Alden 50 Sarasota, Florida
I'm not familiar with the type of voltmeter Catalina uses so it may not be possible to adjust it without a variable resistor in the circuit. It sounds like the meter's internal resistance has changed creating a higher apparent reading so replacing it should cure the problem. If you cannot do that but have some basic understanding of Ohm's Law, you can add a variable resistor of sufficient current rating to compensate.
Sep 29, 2008
1,981
Did not see an adjustment screw in PaulJ's Picture
Of course I did not see any labels either. I actually do understand Ohm's law E=I*R or a variation on that them. So I know E should be 14.5 volts, but finding I or R may take a little more research. Perhaps I can find the make and model in PaulJ's picture and RTFM.
Sep 29, 2008
1,981
It is a Teleflex 72130 Volt Meter
Have not found a manual, but still looking.
Dec 25, 2008
1,580
catalina 310 Elk River
Measure the current draw in series while operational, then measure the resistance when off. Then use Ohms law to calculate what the E should be.
Generally for analogue meters there is a zeroing screw for the needle adjustment, not sure on our unit, but zero it first before you do the actual E reading. Then when you do your calculated E there will not be an additional offset applied to the delta. To correct for high reading add R to the input to ground. If it is reading too low, than the coil is not drawing enough current and probable needs to be replaced. There also may be some an obstruction due to corrosion preventing the needle to swing freely.
goblin
Sep 4, 2006
28
Catalina 310 Pottsboro Tx
In PaulJ's photo of the guts , there looks like some kind of red adjustment screw in the upper right corner of the guage ...............??
Sep 29, 2008
1,981
Will post an update
I will make it down to the boat this weekend to check, but I think the red is some type of cover. But my memory is a bit hszy as it was about 5 months ago I had the cover off and (are you all ready for this? Really ready?) PaulJ did not label that so I am not sure! :D
paulj
Mar 16, 2007
1,361
Catalina 310 Anacortes,Wa
rpwillia
I don't trouble shoot electronics any more but it starts with..... signal in then signal out
E=IR is for designing components.
If you have an existing component, you have to check how it works over the existing scale that is shown on the instrurment...so you need a signal generator......10 volts in then 11,12,13 etc and see where the needle lands on the scale and also see the true range of the meter........My brain is tired already but I think you will catch on.
paulj :troll:
paulj
Mar 16, 2007
1,361
rpwillia
I had to look this one up on the internet.
"Read The F***ing Manual" or RTFM, is an expression that can not be spoken
out loud, but cannot be repeated often enough
paulj :troll:
Sep 29, 2008
1,981
I am working hard to fix my old habits
rpwillia I had to look this one up on the internet.
"Read The F***ing Manual" or RTFM, is an expression that can not be spoken out loud, but cannot be repeated often enough paulj :troll:
Sometimes it is better I use acronyms. But WTF, it's all good!
