Battery Switches
119
Beneteau Oceanus 321 Carters Pt.
Is there any advantages / disadvantages removing the link between Battery bank # 1 and bank # 2 positive switches
Apr 27, 2010
970
Beneteau 352 Hull #276 Ontario
If you disconnect that jumper, you won't be able to use the house batteries to start the motor and you won't be able to use the motor battery to power any of the on board 12v stuff.
It's there just in case one of the battery banks is dead.
Therefore, no advantages to do and many disadvantages if disconnected.
Is there a reason you want to do that???
Beneteau 323 Annapolis MD
Leave it in. That "link" is the 12-volt buss. If you have the indiviual battery swithes, like my B323, the link/buss is not connecting the batteries unless they are switched "on". As Joker said, you lose your flexibilty without it.
437
Beneteau Oceanis 361 Clipper --
If there are permanently linked add a switch between them. You need them separate with the option to connect in an emergency.
"The link/buss" is supposed to be on the oppostire side of the switches from the batteries, so don't think of it as connecting the batteries- it connects all the ship's positive cables to whichever battery you want ON. Otherwise, you'd have to stack all those cables on one stud, and that's more than you should have, and probably more than will fit.
Ron M
Mar 21, 2010
67
Beneteau 331 Rock Hall, MD
I just added a second house battery and changed the switching on my B331. Now the "link" (parallels the two battery banks) is switched. I now have a choice whether the battery banks are paralleled or not. Switches are now House Bank (red), Start Battery (red) and Combine/Parallel (blue, so as not to be confused with the original black "common").
