How far have you gotten thus far?
3,319
How much work have you been able to accomplish this spring? Are you ready to hit the water? Are you on the water?
So far I have:
Replaced the house bank
Ran new Halyards
Replaced the Macerator Pump
Rewired the bilge pump
All I have left to do is:
Put on all canvas
Put on the sails
De-winterize the engine and water system
CLEAN!
Nov 22, 2008
3,562
Endeavour 32 Portland, Maine
I've gone a long long ways, backwards.
Much of the interior joinerwork is torn out.
The entire holding tank system and piping has been removed.
The chainplates have been removed
The standing rigging is all scrapped.
One of the mast spreader mounts is off the mast and the other will be soon.
The exhaust hose is removed.
The propeller is off.
Who knows where it will end at this rate?
Tim R.
May 27, 2004
3,626
Changed engine oil
Changed tranny oil
Installed new radome on mast
Installed new wiring in mast
Repaired and reinstalled steaming/deck light
Ran wiring in boat for new radar
started taping and sandy brightwork
started removing old name
picked new name
removed lots of old NMEA wiring from old GPS
Started reinstalling canvas
Cover comes off and mast up in 2 weeks.
Still have to:
replace impeller
pickup new sails
install standing rigging on mast
Oct 15, 2009
220
catalina 320 Perry Lake
Washed/waxed hull
Bottom painted
Ready as soon as good weather and the Marina can coordinate a splashing.
Dec 27, 2005
500
Hunter 36 Chicago
List so far:
Wash, wax and polish topsides, cockpit and deck
Replace SS trim piece on forward starboard rubrail (dented when trying to dock in a wicked crosswind and current).
Install 2 4D AGM batteries
Install new impeller
Install new Variprop
Have jib repaired (UV panels damaged by sail flogging when furling line came off the drum in same 30+ knot winds that caused docking accident) Done
Install new Joker valve
Finish installing 2 Racor turbine filters
Flush and shock fresh water system
Clean cabin
Fabricate new lines for mooring harness (done)
replace swim noodles on mooring buoy cover
Probably a few more when I get to the boat this weekend
Apr 8, 2010
1,606
Frers 33 41426 Westport, CT
As of now, I am expecting to splash on the 16th. Many of the projects below I have pictures of, and will eventually make it up on my website...
Completed:
*installed new 16/4 wire in mast for spreader lights
*installed spreader lights
*reinstalled halyards in mast
*on/off'd rust stains and streak marks on the hull
*installed 12w solar panel w/ charge controller
*built solar powered windex light (requires no mast wiring!)
*repaired 2 under cushion plywood compartment covers that had slight corner delamination due to moisture
*installed 4th slat holder (http://sailingit.com/blog/archives/70)
*re-hinged the compartment under the companionway so it would open after installation of 4th slat holder
*purchased and installed teak towel rack
*replaced damaged water strainer
*fix mast existing wiring connector ripped loose when installing spreader wiring
*re-rivet mast base to mast (rivets cut off to access conduit in mast for wiring)
To-Do before splashing:
*polish and wax hull
*bottom paint (it's been 2 years)
*install LED anchor light
*install solar powered windex light
To-Do after splashing:
*step mast
*install new 1/2/B battery switch and main bus bars
*install deck electrical fitting for spreader lights
*install new electrical panel
TomY
Alden Forum Moderator
Jun 22, 2004
2,769
Nothing too major came due for repair or replacement. That's something to take advantage of with a 50 year old boat. So I tore out a section of the galley. A repower in the 70's caused an angled bump out to acommodate the longer engine. It was uncomfortable to work around, no toe space, and didn't look quite right.
I started from scratch and redesigned (then built a mockup) it, shrinking the bump out, added a tiny fiddled shelf above and a toe space below. I copied the original Alden cabinetry. The new middle panel swings out for better engine access, head locks into a rabbeted cleat above, latches securely below.
There's a little space behind the big door, any storage is useful. The fixed section to the right now holds a tilt out trash hopper. It lifts out for better access behind.
With that done, I took out the companionway ladder to refinish(still in fine condition after 50 seasons). All is back in place. It left a few loose ends like extending the windlass battery cable, some work on the alternator alignment which has been eating belts, etc. The rest to do is just old boat stuff, like varnishing, that doesn't really count for me. :)
Here's the trash bin. A little small but an improvement over the plastic can that never found a good space. A pivoting latch stops it open, a push and gravity keep it tightly closed. Yes, the gimbal stove will hit it on port, but it still opens 3", enough for the rare times.
This could be controversial. About to use plywood for the back panel, polycarbonate came to mind. It's more impact resistant. It's fire resistant. Come to find out, a 1/4" is equivalent to and inch of wood in sound deadening. Why not have a visual port on the engine? Plus I had some in my shop. Little kids will enjoy it.
The mahogany ply came out of a local dumpster, the reason for the left over paint inside face of door. No I won't be keeping spices in there, a cutting board, maybe an oven pan...
Oct 26, 2005
2,057
- - Satellite Beach, FL.
Hey Roger
Wanna race?
Oct 26, 2008
6,370
Catalina 320 Barnegat, NJ
It's been too damn cold and wet to do much of anything outdoors so far. I haven't started anything and projects around the house are still in the way. Nobody has even moved a boat into the water yet this year and I saw the local rowing club doing calesthenics in the snow the weekend before last. I did see that the first bass tournament was held last Thursday night. It was kind of funny to see all the bass boats on trailers with snow still on the shoreline.
Spring will probably come in a hurry and the boat will go in without being polished or waxed. The projects are minor and except for a few fuel-line related projects (changing the fuel-return hose, exchanging the primary filter housing, and changing the fuel injection line), will have to be done while in the boat is in the water. With all the snow and now rain we've had, I'm not going to bother taking the cover off until next weekend at the earliest.
Sep 20, 2006
2,952
I'm with Scott...... not good weather for boat projects... this was Sun. night
62
Catalina 30 Seabrook, TX
Wow, living in Galveston, Texas is great. Never stopped sailing all winter and I took "Journey" to the local ship yard two weeks ago, had a bottom job done, and been sailing since. Reading this post made me tired, I guess I'll go sailing to relax. Good luck to all of my northern sailing friends.
Nov 9, 2008
1,338
So far we've reuphostered the interior and prepared to repaint. I took a pressure washer to the hull and blew about 90% of the old bottom paint off. I'll scrape the Klingons later, then sand it smooth. I decided on Hydrocoat for a few reasons. Seems like a good product.
RECESS
Dec 20, 2003
1,508
Catalina 27 . St. Mary's Georgia
We are on our fourth trip in 2011. I have been working on both boats but currently we are in a marina at Carrabelle Florida with our Oday 25 waiting for the weather to pass. We spent one night on anchor but then small craft advisories for both coastal and protected waters came. We will be heading through the ICW for Port St Joe in the morning. I am loving the way 2011 has started.
gpd955
Feb 22, 2006
1,164
Catalina 310 Cape May, NJ
Due to weather, I'm a day or two behind but, other than the graphics and bottom paint, she can go back in the water. Hopefully onbe nive day will have me back on track! Splash date is still 4-20!
Jun 2, 2004
5,802
I am this close |<----->| to saying "fagetaboutit". The weather just will not cooperate. And my list is so long. Maybe this should just be a refit year, leave her on the cradle and get her right.
Blitz
Jul 10, 2007
715
Seidelmann 34 Atlantic Highlands, NJ
I noticed some of you rewired your mast - what type of gromments did you use for the through mast penetrations to protect from chafe - and where might I get them. I'm having a hard time finding some for up to 1/2" inside Dia for 213 VHF cable or close to that diameter for wire penetrations.
Thanks,
Neal
Apr 8, 2010
1,606
Thanks,
Neal
home depot :)
