I wonder if this would be a good answer for the problem of water closet lines back flooding into the bowl. Despite dry flushing and a short straight run, I still have enough drain back down off the wall of the hose to be objectionable at times when the joker has a bit of "fluff" in it.
http://www.trapguard.com/
I'm sure it shouldn't be used as a replacement for the joker valve but seems that it would work if put in just after. It fits in a 2" PVC pipe so a couple of Sealand adapters and reducers with a short length of pipe should do the trick.
