Tiller mod question
808
Macgregor 1993 26S Houston
Hey guys,
I was checking out the tiller on my 26s yesterday, looking at adding something so I can let go of it for short periods of time.
I noticed that there is nothing to hold it up. Meaning, I can't rest my hand/arm/ leg on it. It would lay down directly on the lazerette lid, and rub on it when I'm steering, unless I hold it up.
Is there anything I can use that would hold it up, so I can rest a hand on it?
Oh I installed a kinda home made tiller tamer kinda thing i saw on the net a while back. It's a short piece of tubing with a short rod welded on so it looks like a tee. Drill a hole in the tiller for it to stick in. Run a rope across the boat, through the tubing, to the other side. Pull tight, and the tension holds it in position. When you don't want it, just pull it out, and it's out of the way!
Jim
May 4, 2005
4,062
I think someone bent some SS flat metal, and attached from under the tiller to act as a spring.
fwiw, I have a skate wheel under mine, but its a D and totally different setup...
*I also have a jam cleat under the tiller for the times I don't use my AutoPilot.
Oct 18, 2007
707
Macgregor 26S Lucama, NC
Tiller support for 26S
Doehunter- here's what I did. Works good. In the long run, if I see wear on the laz hatch from the glides, I will cut an arc from Formica and glue it on for the glides to slide on. Having the tiller up is much more comfortable; I can rest my arm on it and I don't bang my knees! -Paul :)
1,863
Macgregor 25 So. Cal.
Maybe cut some strips from a plastic cutting block and mount to lazerette lid with counter sunk screws?
Sep 26, 2010
808
I thought about using a wheel of some sort too. It's kinds goofy, that Macgregor made it that way. I thought about remaking the way the tiller attaches to the vertical tube that goes down to the rudder, but I'm not sure it could take the downward torque it would see when I have me leg or arm resting on the end of the tiller. Maybe a roller is the best answer.
Jim
Feb 19, 2010
62
Macgregor 1995 26s Windycrest Sailing Club, Lake Keystone, OK
I wonder if a plastic small chair caster would work. It would only require a small hole to be drilled in the bottom of the tiller and the caster pressed in. A caster would roll easily on the lazerette lid without marring and the cost would be minimal. And it should be able to support the weight of an arm or leg easily.
Oct 21, 2010
350
Macgregor 26S, "Myuna" Brisbane, Australia
Not having read the whole thread and before I saw atwhite2's post (similar concept) I was thinking perhaps a fine piece of rigging wire from the centre of the pushpit to the about 1/3 of the distance from the tiller post on the tiller. Could even have a bottle screw on it for adjustung the height over time to find the most suitable position. Having it back towards the tiller post as far a possible would be good it terms of keeping it out of the road and having minimum intererence with the action of the tiller.
Another alternative would be a block that fitted over the tiller post and had a slot on top that allowed minimal downward movement of the tiller arm (eg. some sort of SS plate that extends 1 or 2 inches forward of the pivot point and underneatht the tiller arm, similar to what many boats have.
It does frustrate me that the tiller rests on the lazarette, but on the other hand it does not seem to have marked the lazarette at all??
Mar 25, 2007
41
Macgregor 26S Davis, CA
Hey guys,
Jim
Ida Sailor made a great stainless steel tiller post riser, which I use and enjoy in my Mac 26S (see picture). Keeps the tiller 1-2 inches avove the lazarette cover withour rubbing. However, I've just looked it up in their page and don't see it anymore. But the idea works great. Cheers, Albert
402
MacGregor Mac26S Victoria Tx
I did it a bit simpler. I cut a piece of a "bunker glide" (plastic strips that take the place of carpeting) It is black, slightly on the soft side. I forget what type of plastic it is.
Anyway, I cut a small square and attached it on the bottom sie of the tiller. The plastic is sift enough that it doesn't make a mark on the fiberglass.
You could also find a "glide" thingy at Home Depot and do the same thing. They have several types. Seems like they are around the cabinet hardware section? They also have some for the bottom of furniture feet.
Jul 7, 2004
8,492
Hunter 30T Cheney, KS
I have the IdaSailor post riser and laminated tiller. It doesn't look like they sell it anymore. It keeps my tiller from dropping. See the inverted "L" at the hinge point.
cscott
Oct 18, 2007
188
Macgregor 26S - 1993 Aumsville, OR
If you have a rear Stanchon, streach a shock cord from port to starboard under the tiller and adjust it to the height you want. Cheap and easy. It works for me.
Chuck
Sep 26, 2010
808
I like this,
Doesn't look to hard to make. I'm gonna check it out.
thanks,
Jim
Jun 3, 2004
1,863
Tie a line to the top rail of the pushpit?
Hey guys,
Jim
Oct 31, 2010
136
88' Macgregor 26D Whiskeytown Lake, CA
I am totally puzzled by the fact that rudder system is different on the S. I had no idea. Where have I been?
