Nicro Vents
7
Oday 25 Percy Priest
I'm considering a Nicro day/night vent for my O'day 25. I'm thinking it would work well on the front hatch. Has anyone any experience with an optimum location for such a vent. How do these solar vents compare to the less expensive passive models?:)
Dec 14, 2009
63
Oday 37CC Norfolk, VA
We've had the solar/battery model installed in our 37CC for about 14 mo's now, batteries have died once in that time but other than that they seem to work well - they are starting to make some noise at this point so the 2yr warranty is about to be worked. From other posts 1-2yrs seems to be the lifespan.
Pat
Jun 7, 2004
1,250
I'm not certain if you are wanting a real breeze in which case I think you are right on. We had a Beckson SS Vent-O-Mate that exhausted 750 c.f. of air per hour with a 7 mph breeze (sounds like an advertisment), but it really worked....on hot Kansas summer days, for 8 years this crazy little ventomate made our cabin probably 20 degrees cooler when we arrived at the boat and opened it up each Friday and it never leaked a drop.....I keep forgetting to order one.....they are fool-proof and exhaust a ton of hot stale air from the cabin and you don't even know they are working...but they don't make a breeze in....only exhaust. Pray for Spring!....order something!
Pat Coulter
Dec 8, 2006
1,085
Oday 26 Starr, SC
solar vents
Nicro solar vents do a decent job, but yes they will rattle, silence is not a given. Usually they work on sun light after the batteries go dead. If you want complete silence then do not expect it to be mechanical on a boat.
I recently saw a style, maybe newer nicros, that had replacealbe batteries. Mine are sodered in.
I see lots of boats with the nicro's cut into the plexiglass of front hatches.
Some of the other brands are not stainless steel or UV resistant plastic. However, if they use same size hole, they cost less. Nicros have good track record.
Thanks for Beckson SS Vent-O-Mate info.
Ed K
The new employee stood before the paper shredder looking confused.
"Need some help?" a secretary, walking by, asked.
"Yes," he replied, "how does this thing work?"
"Simple," she said, taking the fat report from his hand and feeding it into the shredder.
"Thanks, but where do the copies come out?"
Bruce Wilson.
Jan 24, 2011
49
Hunter 30-2 Lake Champlain
Not to steal your thread, but has anyone found an affordable solar-powered vent with a battery for overnight? I been looking online for a couple years now and have only found extremely expensive or "not worth the box they're shipped in" models. I'm just looking for one I can drop over the anchor locker up front while we're on the boat to draw air through the cabin.
Dec 8, 2006
1,085
Oday 26 Starr, SC
solar vents
Amos,
The Nicro vents will do exactly what you describe but yes they are pricey. Older models have the batteries soldered in so are not easy to replace.
There are other manufacturers out there, check Defender and other marine suppliers. In fact ask Capt Herring, the host of this site if he carries a less expensive brand. Maybe with summer still some months away, Capt Herring can find an alternative supplier at significantly less $$$$.$$ Give him some meaning work instead of monitoring posts...
Ed K
sPk
Jun 12, 2005
111
Oday 25 Apostle Islands, WI
Re: solar vents
I installed a Nicro Night/Day vent in the front hatch and am very happy with it. The motor died after a year or two but they replaced the whole unit for free. With a fresh battery & plenty of sun, it will run all night. They come with two fan blades, one for exhaust one for in. They are pretty quiet but sometimes you need to adjust the blade to ensure they stay quiet.
