O'Day 272 Custom Electrical Panel
Very nice work. Do I detect an ashtray? Thought they went out of style a few years ago. :)
Dec 3, 2010
74
Oday 25 N/A
I could imagine a few cigarettes were smoked while having to do all that wiring. Looks very nice and professional.
bria46
Jan 15, 2011
286
Oday 272 Waukegan, IL, Sarasota, FL
You are correct! I drilled Two 2 inch holes in the lower hull liner (the area directly behind the settee upper cushion backs and pulled the wiring thru, Forward and Aft with a fish tape.
Pat
Jun 7, 2004
1,250
Check out my self installed custom electrical panel located behind the icebox on the port side. I used all Blue Sea Systems products for the installation.
I am very impressed....the installation is beautiful. Is there any concern with being so near the stove. I suppose not....It makes your boat look cool....how about some other pictures of your boat?
Pat
Pat
Jun 7, 2004
1,250
I see the stove is gone....that's the only thing I could not do...we use it every weekend...
bria46
Jan 15, 2011
286
This 272 never had a stove installed from new. However, The AC Panel has a circuit breaker for a microwave oven. The microwave oven will fit on a folding, drop down shelf on the port side of cabin, on a shelf directly in front of the midship storage cabinet. The AC wiring to a grounded duplex outlet is already installed. The photo attached is of the origonal location of the DC power panel now replaced with the new digital thermostat control for the air conditioner/heater unit
Pat
Jun 7, 2004
1,250
my 272 LE has an Origo double burner stove...I think your installation is beautiful and have often thought the boat should have come with more of a panel, but after having the boat for 25 or so years I'll probably not end up doing that. I use the origo often ...this last summer three times went out on early sunday morning sails then up into coves to anchor, swim, and cook bacon and eggs...even egg's benedict....& coffee... The wood on your boat looks really good too. I'd like to see some more pictures of your cabin...and other improvements. Patrick
Aug 23, 2005
28
Oday 28 Racine WI
Dear Bria 46,
I am very impressed....the installation is beautiful. It makes your boat look cool, but what could you possibly hook up to all those switches? Is this the latest style in Waukegan, IL? It looks like a computer keyboard.
Bob Lendvay
bria46
Jan 15, 2011
286
Thanks Bob. I found many things not protected by circuit breakers. I used some 1 Amp breakers for delicate electronics such as the Raymarine auto pilot, Depth sounder, speed indicator, etc. All of the other breakers were sized to be 30% to 50% higher than the actual load current. It is silly to have all 15 Amp breakers. That's the best way to fry delicate instruments.
Aug 23, 2005
28
Oday 28 Racine WI
Dear Bria 46,
Now I'm really impressed. Your electrical system is probably bulletproof. I never thought about adding switches to fine tune fuses. Brilliant! Very good job.
Bob Lendvay
May 8, 2010
6
Oday 272 Lillian, AL
I just finished re-doing the interior of my 272 LE and wished I thought about the electrical panel. You did a fantastc job!
Doug
Dec 27, 2009
37
Oday 272 Great South Bay
How did you secure the cabinet for the electric panel and other instrumements to the hull?
bria46
Jan 15, 2011
286
I didn't feel it nesessary to attach the panel to the hull. I used a 3/4" piece of marine plywood, mounted it by #10 - 1-3/4" long sheet metal screws thru the storage shelf (the unit with the plexiglass sliding doors). On the other end I built a side panel that followed the curve of the inside of the hull and then used a couple of teak mounting blocks and #10 - 1-1/2" long screws. The top of the electrical panel was made out of 1/2" marine plywood. I built the top panel also following the curve of the hull. After many, many hours of fitting the panel parts to the top of the counter I cut out the holes for the Blue Sea Systems AC/DC panels, VHF radio, Analog gauges, and Raytheon 530C GPS. Then after the final fit was perfect I covered the outer plywood surfaces with 1/16" teak veneer. The top shelf was covered with Wilson Art Formica teak veneer. This process took me approx. 200 hours. I have removed the electrical panel a few times by removing all mounting screws and tipping the panel forward and laying the panel on top of the ice box/counter top. Would I do it again? YES! I found this installation much easier than than my Air conditioner installation.
Aug 20, 2010
1,399
Oday 27 Oak Orchard
That is a superior job bria. I like the Blue Sea breakers acting as the switch with the LED indicators. I might just steal some of your ideas as fuses are best relegated to antiquity.
bria46
Jan 15, 2011
286
Thanks for your comments. I've been following your extrodanary reconstruction of your O'Day 27. You are welcome to "steal" any of my Ideas. I will be more that happy to assist you with your future electrical projects. Brian
