I have searched what is available here (100+threads), but can't find the answers I need. It was discussed here http://forums.hunter.sailboatowners.com/showthread.php?p=474808&highlight=compression post repair but, as usual was left hanging.
If you don't know you have a problem for sure, just look in the forward, hard to see, area of your bilge. If you find this, you have a problem.
Does anyone know how the steel pipe was put in? It does have a flange on the top side, that seems to have had a bit of glass cloth thrown at it when it was installed. The bottom, I can't tell for sure. Is it just glassed in? If I can figure out how to remove it, I can have a new piece made of stainless. It will be difficult to get the length correct, but trial and error should eventually pay off. Any ideas how I might proceed? Once I have it figured out, I'll have the mast pulled, and tackle the job.
There has been no signs of a problem, but figure there will be very soon. Also, what holds the teak compression post in place at it's base, and at the cabin top?
I have a few projects ahead, but this one may be the most challenging. She is a nice boat, and sails beautifully. So, to me it should be worth the effort to make things right.
