Bad Vibrations
1,981
Catalina 310 #185 Quantico
Read MS's Recent Other Post
Bill1565, Read Maine Sail's other post here "Replacing Motor Mounts / The Snowball Effect". Really good and detailed post about some similar problems. You really need to replace that Motor Mount (and perhaps the others) ASAP before it causes other problems. It's really cold up in Maine right now, perhaps you could sweet talk him into visiting. :dance:
thanks. I saw Maine's post. I had the two aft motor mounts replaced. rubber on both had come unglued from mount.
Motor looks to me to be cocked to starboard and list to port. Shaft seems to line up ok. Gonna let that sleeping dog lie for a while unless new mounts break
Gonna look into replacing front motor mount with something physically narrower to get away from port side bulkhead, but not till summer down time.
Boy I envy Red's surplus of space, I have a devil of a time even reaching my oil filter, much less removing it.
11,760
Other than looking pre-loaded it looks ok..
than looking pre-loaded it looks fine..
Don't know what you mean by "pre loaded". Mount seems ok, but note paint stir shims to keep mount from vibrating against bulkhead. Starboard motor mount has slightly more room, maybe 1/2" total clearance
Jun 2, 2004
5,802
Redhead, is that your Jeanneau engine bay? Sweet! But no, all the Hunters that I know about have four corner mounts. There was the one small flat Yanmar that might have a single front mount. The Cherubinis that we are discussing here have half the room that yours does. Looks big until you stick the engine in there. And I have one of the new small 3YMs.
890
Hunter 34 Toronto, Ontario Canada
I have had a problem with what sounds like the shaft thumping on the tube through the hull at about 2000 rpm and only after the motor/drive train is warmed up from sustained running. Never at start up.
I am about to replace the shaft and prop - old one was a "non-slip tipped" 2 blade. I am probably going to a Campbell sailor 3 blade. I have long suspected the mounts but how do I tell if they need replacing. The cutless bearing looks fine after 6 years. The motor is a Yanmar 3GMF and the mounts (x4) are over $200 each so I want to be sure.
11,760
I mean that the mount looks cocked off the port side of the boat and seems pre-loaded. Pre-loaded means that if you took the motor off it would not be canted, twisted or cocked and would pop back to it's natural position. After years of being pre-loaded though it will not spring back but it does not mean that it was not pre-loaded.
With the motor properly aligned and installed there should be no pre-loading of any of the mounts other than the angle of the motor mount brackets which are not always level with the motor beds when properly aligned though they generally should be.
Alignments should ALWAYS take into account the proper centering thought he cutlass and shaft log. Many owners and yards simply adjust the motor until it seems aligned to the coupling. This may be only half the job and doing only half can cause the shaft to thump the shaft log or cause shaft whip due to side loading from the cutlass or stuffing box. You need to align the "system" not just the flange to the gear box as many so called "mechanics" do..
Some things the books won't tell you:
1- After making an adjustment re-tighten the motor mounts to the beds and wiggle the engine from the valve cover or other good holding point re-settling it in the mounts.
1A- The reason for doing this is to make sure none of the mounts get "pre-loaded" during the alignment process. The mounts should all be sitting naturally under the motor. Any pre-loading, usually side to side, will cause issues once you lock everything down. For instance if you move the front of the motor to port and the starboard mount only leans over but does not slide to port along the engine bed this is going to be a pre-loaded mount. When the engine is properly aligned the studs will be vertical when looked at down the centerline of the boat.
2- Please don't hit your engine with a hammer...
3- A 2X4 used as a lever can be used to move the engine side to side.
4- Dish soap can be used under motor mounts to make them slide on the beds easier for side to side adjustments. It will dry and become non slippery by the time you are done.
5- If a gap rotates around the coupling and does not always stay at say, the bottom, or top, it is a good sign the shaft is bent.
6- Every time you put the feeler gauges in between lightly push the couplings together.
7- Leave the coupling bolts in but loose.
8- Always do a final adjustment with the rig tuned and the boat having been in the water for a few days, a week is better. You should always do a rough alignment on shore down to .004" or .003" but will usually need to tweak it with the boat in the water. Some boats move more than others. Generally the shorter the shaft the less you will notice it move when in the water. Our CS-36 moves about .001"-.002" from in water to out.
9- When aligning out of the water be sure the shaft is passing though the cutlass in the dead center and parralel. This will insure that the shaft is aligned to the cutlass. The shaft when passing through the cutlass bearing must have a constant contact through the center over it's entire bearing length. After the shaft is centered in the cutlass check to make sure the shaft is passing through the shaft log in the center. I have seen many DIY's "go to town" on a re-alignment and not pay attention to the shaft centering and only to have the shaft slapping the shaft log under power later. If you get to 98% on land, and centered, you'll only need light tweaking once in the water.
On a short enough shaft one secret trick I employ is to do the rough alignment with the cutlass bearing not yet installed. This allows you to see side to side centering very well and allows you to measure it accurately as it passes through the p-strut. Side to side is always the toughest as it means moving the engine side to side without pre-loading the mounts. The up down can also be roughly centered providing you don't have a lot of shaft sag from the coupling to the prop end. This can be pre-measured or determined first. Once you get everything as centered as you can the cutlass can be pressed in and a final precision alignment done.
10- Remember this entire procedure is predicated on the premise that the factory built your boat so the shaft log center lines up with the cutlass bearing center. If you are skeptical of this you'll need to confirm these two line up before doing anything. The shaft log may not line up with the cutlass and in this case you always want to align the shaft to the cutlass so it rotates perfectly centered in the cutlass, preferably with a new cutlass bearing, or only slightly worn. On many boats this means the shaft does not or can not pass through the center of the shaft log without major surgery. This can lead to other issues with stuffing boxes etc..
11- The engine should be aligned to the cutlass bearing firstly then the shaft log secondly but both are important as you don't want an off center stuffing box wearing the shaft either. On our boat the shaft log and cutlass bearing line up almost perfectly but this is not all that common.
12- If you have an exhaust hose or engine driven compressor belt connected to the engine that can "hold it" disconnect it while aligning so you don't have any competition fighting you. Once aligned re-connect these items in the aligned position. For fridge compressors only adjust the belt so it does not slip and no more. Do not overtighten these belts. Doing so will throw your alignment off if the compressor is not mounted to the motor and is mounted to the engine beds or vessel.
13- A lot of shaft vibration on small dia shafts comes from shaft whip and not the actual small .001" alignment issue. There is often a rather long, bearing free, distance between the gear box and the cutlass and if the couplings are out, even a little, it will induce shaft whip or what I refer to as the "jump rope effect". If you really want to get anal about alignment do the following. Once the couplings have been aligned and the bolts are tight locate a dial indicator, set it up, and turn the shaft to by hand to be sure you have a true concentrically rotating shaft. Before running the dial indicator on the shaft surface clean it with Scotch-Brite or wet sand paper so it is smooth. If the couplings are not aligned or the packing gland is applying a side load the shaft won't rotate concentrically.
14- It should be noted that an improperly centered packing box, after alignment, can induce a loading effect to the shaft and can also cause shaft whip. Once aligned simply loosen the hose clamps and adjust the stuffing box to a "relaxed" and centered position around the shaft so it does not impart any side loads. If it is not well centered loosening the stuffing box hose and adjusting it won't do much of anything. It needs to be very close to center in order to get some slight relief from the stuffing box. If you can't get it centered in the shaft log a PSS seal is much more forgiving at relieving side loads..
15- To help minimize shaft whip a balanced prop that has been lap fit to the shaft, a proper alignment and a coupling that has been fit and faced to the shaft are all components of the mix.
16- It is also important that the exposed space between the prop and strut does not exceed one times diameter of the shaft it's self.
Wow!! Thanks Maine. Maybe I'll revist motor mounts and stuff next summer. When I bought the boat we used a laser pointer to align the new cutless in the re mounted strut with the shaft log.
Dec 30, 2009
680
jeanneau 38 gin fizz sloop Summer- Keyport Yacht Club, Raritan Bay, NJ, Winter Viking Marina Verplanck, NY
Yes, it apparently is a large space, is that yours in the photos?...How do you get at the stuffing box? My old motor and trans were not only bigger, the combo was around 600 lbs heavier also. Red
Jun 2, 2004
5,802
Ah yes, the stuffing box Redhead asks about. On the H37C you had better have the newer model that has the side access from the quarter berth. Or like my 1979 you cut it open yourself. You still have to lay with one arm asleep under your body while your face is on the side of the water heater. Then do everything with the other hand.
Bill, I'm betting MaineSail has a speech-to-text app on his computer. No one can write that much in one day. And Maine, I feel stupid asking since I spent 40 years in the computer business, but how do you post your pictures?
11,760
I don't write that much in one day.;) Having been posting on these forums for 10+ years I have a lot of stuff already written that I can clip, cut and paste from. I do often type new but I type pretty fast.
As for picture all my pics are hosted on my pBase site. I then simply link to them. They are not hosted here..
Use a photo hosting site and the
icon.
My personal preference is PBase. Yes, it's 23.00 per year but SOOOOOO worth it! It is very professional looking and you get tons of space for your $23.00. It's also super easy to link to and it let's you choose sizes. You also DO NOT have to re-size your images to upload to PBase.
Our PBase Gallery (LINK)
PBase Small:
PBase Medium:
PBase Large:
Go ahead and go to my web site and choose a photo. Next open it and copy the web address of the picture. Now click on this:
and paste the address into the pop up box being sure not to duplicate the http:// part. At the end of the web address for one of my photos all you do is add .jpg to it, at the end, and hit ok.
In the
pop up box it will look like this: http://www.pbase.com/mainecruising/image/84961079.jpg
