310 water line
DaveGL
Nov 11, 2006
6
Catalina 320 Mystic,CT
Previous 320 owner. I looking at 310's. Why do most 310's sit lower aft at the water line?​
Sep 29, 2008
1,981
Catalina 310 #185 Quantico
Simple
Cause that is where the owners sit. :redface:
Actually, I have no idea. I don't think the 309's sit as much aft either.
CCHer
Jul 7, 2010
230
Beneteau 37 Cranes Creek, VA
I'm a new owner (last June) and noticed a half inch or better rise in the bow when I emptied the fresh water tank. However it seemed rest pretty straight when the water was full.
Tom J
Sep 30, 2008
2,325
Catalina 310 Quincy, MA
Yep, watertank is under the v-beth. If you don't have a gauge, you can almost tell how full the tank is by checking the water line at the bow.
Dec 25, 2008
1,580
catalina 310 Elk River
Ok, here it a question:
Will a boat sit higher in salt water v/ fresh?
Dec 25, 2008
1,580
I think the answer is that it is insignificant, because unlike your body that is 95% water, the volume in a boat is mostly air, so the difference in density between air and salt water and air and fresh water is insignificant.
