To Strain or Not To Strain
6,243
S2 9.2a Fairhope Al
i have been working on and Almand 35 and my S2 9.2 and it has come to my attention.... neither one has a raw sea water intake strainer ...except for the kingston cock (s2) and the grilled bronze through hull (almand 35)...now i am wondering why not....is it bad news to use a strainer in the engine raw water intake.....theses boats are closed cooling systems and if so why ?????......
regards
woody
Jun 2, 2004
5,802
So you are saying that anything that fits through the intake and hose gets in? Makes one wonder what you have been grinding up with your water pump? I suppose if you always motor in clean water then a strainer isn't necessary. Your seawater pump is probably all bronze so maybe it will last longer than with a rubber impeller. But I sure wouldn't take the chance.
njsail
Feb 18, 2010
216
Bavaria Ocean 40 CC Forked River
As Ed suggests you might want to rename the post to grind stuff in your water pump or not. Unless your sailing in a bathtub there is a good chance eventually something will get ingested into your raw water system. If it enters the intake then it will pass into your raw water pump and your impeller with either chew it up, it will chew the impeller up, or spit it through. None of those choices are preferable. I would recommend some type of strainer prior to the water pump. Make sure when you install it to have it properly installed above the water line so when you open it it doesn't become a fountain.
Jun 6, 2006
6,990
another view
We have concrete pumps that "pump" gravel.
If the bronze thru-hull "strainer" is in good working order it will only allow small items (fish, flotsom, jetsom etc) to enter. The grill size is pretty small on the ones I've seen. Not really much different than having a full bore hole and a strainer. I had one just like it for 5 years and never had any issues.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
theses boats are 26 years (almand) and 31 years old(s2) and i am not sure what the standard was back when they were built...but i feel like you in that i think they should have a strainer......i am also thinking that the sea cock would stop the fountian effect when it is opened up to service it.. in the event i have to mount them below the water line.... i am not sure what the ABYC recomends.....
regards
woody
Nov 6, 2006
10,051
The heat exchanger tubes are probably the smallest passages in the seawater side. If the strainer openings are about half the size of the tube diameter, you'll probably be fine.. My strainer openings are about 1/6 the tube ID.. Ya probably don't want a lot of solids accumulation in the muffler also.
Dec 2, 1999
15,184
Woody:
Just because it has not happened does not indicate that it will not happen. I think it would be prudent to put a strainer on both of these engines. Our marina has just started getting infested with some sort of sea grass (fresh water). We did not have a problem with this 3 years ago and now the owners are working most of the warm months keeping it at a manageable level.
Even with a strainer ther is no guarantee that you cannot suck up this stuff, but as you know these incidents normally happen at the worst time. Having your engine over-heat when you are trying to get back to your marina in a big blow is not my idea of a good time.
You can get strainers for a little over $100 or spend $1,000 but it may save you money in the long run.
My '85 Hunter 31 came with a strainer.
Sep 29, 2008
1,936
Catalina 310 #185 Quantico
Get crap in my strainer all the time
Usually those little 1" pine needles that float in the water. Think about what those would do to your heat exchanger over time. I would put in the strainer.
11,701
I personally detest external strainers unless they can be opened for cleaning. I generally prefer to up-size engine intakes to a minimum of 1" and then run a heavy duty Perko or Groco bronze strainer with smooth sweeping ells if needed. I have seen and dealt with far to many issues with external strainers and much prefer the ability to run a "snake" through my thru-hull if necessary from inside the vessel to clear a clogged intake..
This past fall I fixed a perplexing and multi-year over heating issue for a guy at the boat yard. The owner had spend a LOT of money replacing hoses, pumps, flushing the engine and replacing the t-stat and HX but he still over heated. He had hauled the boat early thinking he now had to replace or rebuild the engine. He was getting water flow but never measured the quantity against what it needed to be.
After chatting with him I walked up to his boat, took my screw driver and cleaned the junk and paint from his external strainer, then removed it can cleaned out the barnacles from inside it. His overheat problem was solved after many years. He is now flying sans external strainer and installed an internal one.
Dec 2, 1999
15,184
MS:
"Detest"! I guess you really do not like those external strainers.
I would have to agree with you that they can/may be a problem. As for the paint, that should have been addressed by the owner or the yard before the vessel was relaunched.
Fed up w/ personal attacks I'm done with SBO
Last haulout I did exactly as Mainesail said with the exception of thruhull size. I went from a 1/2" with external strainer to a 3/4" open type. My raw water strainer is mounted slightly below the static waterline (no choice in my case) which provided a small benefit. After cleaning (thruhull valve closed) when air has been introduced into the strainer, simply cracking open the lid seal (valve now open) automatically purges the strainer.
Other benefits of losing the external strainer are you can get some bottom paint up inside the thruhull and if you let the paint go too long and get some growth in there, it can be rodded out from inside the boat. It's a wet process but no worse that inserting a knotmeter paddlewheel.
RichH
Feb 14, 2005
4,773
Totally agree with Maine. I Vehemently DETEST the strainer type through hulls - in 'growth areas' they become 'breeding baskets' for barnacles 'inside' the grill.
For most liquid systems to prevent blockage from large particles, etc. the 'rule of thumb' is that the 'strainer' retention size needs to be at least 1/4 smaller than the smallest 'orfice diameter equivalent' in the system to prevent 'bridging' of the particles. Bridging is where particles jam together mechanically and then block the flow.
11,701
It does not have to be wet at all. Simply make your intake hose a little longer than it needs to be so that when you remove it from the strainer barb, with the seacock closed, you can lift it above the static waterline, open the seacock, and ream it out.. Very, very simple.
11,701
MS:
Yep, after spending nearly three hours one day, in really, really cold water, even with a wet suit, trying to get eel grass out of one, I vowed to never, ever have one again.
They can be a safety hazard, there is little to no need for one, better straining options, and you can far more safely ream out your intake from INSIDE the vessel a huge safety margin when you don't have to physically get into the water. In one season here in Maine I was in the water three times with a coat hanger...:cussing:
Some reasons why I don't like them....
Beyond that many boat yards, some builders:doh:, and DIY's install the scoops BACKWARDS on sailboats and many have actually caused their engines to become hydrolocked. If they face forward you risk physically scooping sea water up and over the siphon break then filling the exhaust and eventually the cylinders of your engine with sea water.
This strainer, like many out there, is another potentially expensive mishap waiting to happen. All it takes is some rough weather and a good surf down a wave to fill your engine with salt water. Facing them backwards can also add unnecessary vacuum on the raw water pump. Sailbaots should ideally have round, non-directional strainers, not scoops, or my favorite, none at all.
If you feel you absolutely must use one make sure it can be opened.
External strainers are NOT clog proof and if they can't open it can be nest to impossible to clear without removal of the external strainer screen. The worst ones are where the strainer is actually integral to the thru-hull fitting, and can't be opened or even removed without physically cutting it apart......:doh:
Even without the pictures (yikes!) it seems counter-intuitive to put something on the outside of your boat over a small opening (the intake) that REQUIRES continuous flow to cool your engine with something with even smaller holes.
Those things are junk and have no place on a boat.
And internal strainers, whether below or above the waterline, are a great improvement over nothing. In my arrangement (from the factory and/or PO) the strainer is right above the intake seacock, so I can't ream it out with a dowel from there. But I can, and have, blown out whatever was clogging by intake with a dinghy foot pump connected to the hose to the raw water pump. Works just fine.
May 23, 2004
3,319
I really agree with the statement that having an external strainer is a bad idea in growth areas. MS is right and he didn't need to post the pictures to prove it but, what the hell, it proves a VERY valid point.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
thanks again for all the in put to all of you ......i may have used the wrong term regarding the strainers ...i was refering to the fact that they had no internal strainers what so ever ...the only ones that were on theses boats were the ones like in the pics MS posted...i was concerding useing that type in conjunction to the internal ones like the groco or perko but have about decided to use only the mushroom style through hulls and the canister type on the inside as all the evidence points in that direction ...once again thanks for the responces......
regards
woody
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
Woody,
Watch the flea markets and eBay and you can often find the good old Perko or Groco sea strainers. The Perko's will outlast your hull and can be very easily rebuilt when needed..
Rebuilding a Perko Sea Strainer (LINK)
thanks MS for the advice..... i do like the old bronze stuff...it cleans up so well in my bead blaster and comes out looking like new again....i was lucky enough to find one down in Texas about 5 or 6 weeks ago in antisipation of this for my boat for $30.00 cash...with all i am doing to put this boat up to bristol ....i need all the advice i can get and the sweet deals too (lol)....
regards
woody
