Indentified multiple upgrades and possible repairs on my 1980 CAT 30. Starting engine has gotten more difficult, exhaust leak, water has potentially fowled the glow plugs, engine is running hot. Based on my research I am diving into plenty of items. I plan to remove the cabinet over the engine to do a complete inspection. Expect to find the lift muffler inlet coupling has failed. Plan to unwrap exhaust riser piping to determine if replacement is required along with the new version hump hose. Plan to take the 2" heat exchanger apart and determine if it should be replaced with the 3" heat exchanger. I also plan to perform the Project: Glow Plugs which will include a starter solenoid. Of course with all that complete, the glow plugs, thermostat, antifreeze and oil will all be changed as well.
Does anybody want to discourage me?
Albert
New to sailing but learning fast
Albert
