anode location
1,580
catalina 310 Elk River
Anyone ever change the anode on the stock 20gal water heater? If so, did you have to pull the unit to gain access?
gpd955
Feb 22, 2006
1,164
Catalina 310 Cape May, NJ
Glad you asked this. Was on my list of things to do before spring and I was going to ask the same thing.
Sep 29, 2008
1,962
Catalina 310 #185 Quantico
It has an Anode?
Would be interesting to know where it is and what the part number is.
Dec 25, 2008
1,580
Not sure about that, 1/2" thread seems too big, but could probably find them @ West Marine.
Tom J
Sep 30, 2008
2,325
Catalina 310 Quincy, MA
The anode in my RV's hot water heater is about 10" long and about 1/2" wide. Wonder if the one in our boats is similar?
Sep 29, 2008
1,962
After I winterize
yeah, I am holding out, but once I winterize, I will take advantage of that heater bypass I put in last year (which helps drain the heater) and find the anode and pull it out. Perhaps this time I can remember the camera and get pictures.
May 3, 2008
190
Catalina 310 Catawba Island
One more bit of maintenance in an area of the boat where my fat butt doesn't fit. How necessary is this maintenance guys?
Tom J
Sep 30, 2008
2,325
Not sure how necessary it is to check the heater anode. This is first time I've winterized the boat since I bought it in 2005. But, since the boat is 7 years old, (hull # 231) I think I'll check it in the spring, when I remove the bypass.
Dec 25, 2008
1,580
Stinky hot water is a clue to a need to replace the anode.
BTW, I took off the cover for the input AC power connections to see if that was where the access to the anode is, not. I guess I will have to pull the HF2000 to find it.
I did discover that the ground connection was completely corroded off.
For obvious saftey reasons, might want to check yours.
Sep 29, 2008
1,962
I did an RTFM
Don't see any anode listed anywhere. Here is the drawing. Have I missed something :eek: or am I correct? :dance:
1,580
Your correct, maybe there isn't one. Would seem silly to design without, but if there was it should be on the side with all the other fittings?
Mar 6, 2008
332
Catalina 310 Scott Creek, VA
From the second link in post #4 above "...attach [anode] in place of the drain plug and it will help inhibit such corrosion." My heater has a gate valve with a garden hose fitting for the drain, but I suppose you could exchange for a zinc.
Sep 29, 2008
1,962
Valcour wins the prize!
First I am surprised PaulJ wasn't all over that. I guess if you are worried about your heater you replace the drain with the anode.
Dec 25, 2008
1,580
Accually with the correct fittings you could have both. I don't like the current drain valve anyway, very difficult to attach a drain hose fitting to because of interfearence with the EX input fitting from engine, or is that the return, I'm not sure it makes a difference.
Mar 6, 2008
332
I ran a permanent piece of hose from the drain up forward to the bilge so I don't have to mess with it to winterize the H20.
Dec 25, 2008
1,580
I don't dump the 20 gal of water into my bilge and make my pump work unnecessarily.
I have a washing machine supply stub hose connected to the drain on the water heater. This makes it easier to connect a hose to it. To drain I take a 12' garden hose fill the hose with water block the end, connect the other end the stub and siphon it out, I fill it the same way. I also siphon out my water tank. Anything to keep those pumps from extra duty.
Tom J
Sep 30, 2008
2,325
Actually, the anode in my RV's water heater is the drain plug. Could easily work the same way on the boat. I usually just drain the heater right into the aft bilge anyway. Helps to flush all those salt crystals that build up in that area.
