Low Moaning Noise - Wind Transducer
114
Hunter 340 Bremerton, WA up from Woodland
On our H340, over the last couple of months, we have noticed a low, moaning acoustical noise that comes and goes inside the cabin. As near as I can figure, it seems to be related to the masthead anemometer as the noise seems to peak and wane at particular wind speeds. I can vary the pitch and volume of the noise by tightening/loosening the topping lift. Doesn't seem to be wind-in-the-wires type of noise but rather a reasonance in the rigging system related to the anemometer. Anybody experiencing a wind transducer failure that displays this kind of symptom? Any other ideas?
Ross
Jun 15, 2004
14,693
See if it stops on Monday. ;)
Jun 4, 2004
834
Hunter 340 Forked River, NJ
My 340 does the same thing. Yes, ease the topping lift or the main sheet a tad and that should help. Once in a great while I also get a weird vibration in my rigging from the acoustical signal of propeller driven boats going by my slip.
Jan 3, 2009
821
Marine Trader 34 Where Ever I am
I suspect you have a rope topping lift and this is the culprit. Loosening it will help, but unless you have it so loose that the boom swings, it will not go away and that creates another noise issue. We finally replaced ours with a combination vinyl covered wire, think lifelines, and rope It went away. Chuck
May 10, 2004
114
Thanks, all. I will definitely check Monday per Ross, but won't hold my breath (I am staying in the middle on this one).
It is making sense, thanks to all your collective smarts and experience, that wind-in-the-wire resonance is probably what I am dealing with. Good news, no anemometer repair trip up the stick. Next week I will try a clever suggestion from the archives and wrap the main halyard around the topping lift a few times (to disturb the airflow around both) before stowing it at the boom end.
Beneteau 323 Annapolis MD
Ever Blow Across The Top Of A Bottle? Maybe Less Likely The Cause On Your Boat, But Maybe Wind Across Some Mast Openings Would Make A Similar Sound?
zeehag
Mar 26, 2009
3,198
my formosa makes different pitches at differing wind speeds--is your rig--is not bad- can tell wind speed without looking after not much time..LOL...
