Dan
Ed.....Thanks for reply....not an Obama fan....I served mycountry honorably w/25yrs military service....Now, let get to the bilge.....water coming in from area I described....no BS pls.....just an answer from anyone as to possible areas of leakage...No intake hose for any kind of bilge pump...Thanks in advance....
My O'Day 26 was a project boat. Bought it from a guy who got transferred/took job in California from southeast. Had not been able to come back to boat in three years. Only then because it was damaged by wake caused by cigarette boats racing in front of dock.
I first took to a rented garage and did some big time bottom work and other work that was best done indoors. Used boat life caulking and installed new front hatch.
When I took to lake, after first rain, it leaked in many places. The Boat Life Caulking did not work.
For the front hatch, I took back out and reinstalled using butyl tape sealant. This stuff can be used for any on deck sealing issue such as hardware.
Then I went around and resealed the leaking hardward with NP-1 roofing sealant.
I still need to take off rub rail and reseal all retaining screws, but today leaking in neglible.
One day when heavy rain forcast, I went and sat in boat and crawled in under cockpit, etc. I was able to track down small leaks this way. If you do not fit, you need to get someone who can crawl around and in with flashlight to do this. This method is often used with hose spraying water on suspect places. However, some leaks take an hour or so to be identified so a heavy constant rainy day works best.
Others have pointed out places to look. Take all advice offered and make list. Take out rubber cosmetic plugs so you can reach inside and look inside of hull areas and cabin liner. Liner has lip which others have discribed that takes water from where it leaks and transports to other places such as aft to run into bilge.
Such leaks are common in older boats. Owners have to be dectives and find sources. Usually there are more than one source.
If water is coming from where keel attaches to bilge, then a couple of years ago there was extensive discussion on that very subject. Water often migrates thru layers of FRP in boats. Finding source is sometimes challenge. The on your back with the magnifying glass method has already been discribed.
However, I would eliminate all other sources first, as described above and in other replies to your post. Also, learn to search archieves. Also, Rich and Keith have replied already. Post pictures for them to comment on. Keith will comment notwithstanding his politics. He is still young and needs to read history about the failures of socialism and dictators such as his idol Obama.
Again, try water from outside test and send pictures. Small digital cameras can be had cheap.
Ed K
