Phil, please check out this reference
http://www.marinelightning.com/Information/GroundingConcepts.htm
Take a look at sections 4.2.1, 4.2.2, 4.2.3
Phil, what do you believe the potential on the conductive mast would be? If its not uniform across the surface of the mast, ohms law says current would have to continually flow. But where would it flow to (there is no circuit path)?
If the mast does take on a single potential (and I think it will take on the single potential of its mid point which in this case would be 100 KV assuming no charge flow Since the mast is all at one potential, the the top of the mast is also at 100KV. But the free space potential at this height would have been 200KV. So at the top of the conductor, the potential goes from 100KV to 200KV in a compressed distance compared to free space. So the conductor did influence the electric field in the vicinity of the conductor- which is also what I believe is shown on Dr Thomson web site I linked to.
I'm not sure what you are implying by saying my mast is not an insulated conductor - some point I missed (the mast on my trailer sailboat is an insulated conductor). But assume in this case a conductor of length 20 foot and it is just off the ground (which is at ground potential). Charge is brought over the ground by a cloud such that an electric field is induced. In the free space away from the mast, lets say the potential at 20 feet is 200KV (ie, field gradient is 10KV per foot). The mast mid point is at 10 feet.The corners of the tank compress the equipotential surfaces just outside it and result in a local enhancement of the electric field. As a consequence the inside upper corner is likely to form a sideflash to the lightning conductor, and the outside lower corner to the water.
