again with the Walnut
1,580
catalina 310 Elk River
I would have to disagree about the warping especially in a moisture laden environment. My experience with the wood suggests otherwise. I'm not siting some printed material, only my direct experience.
I would like to understand what is in the Juglone (this is what makes your hands turn black when you handle it). What is the oil content and how does it compare with teak?
Jun 16, 2010
98
Lancer 25 Newbergh
I guess if you think if you spout long enough it will be true! Are you challenged in some way? I read what you sighting and still do not see any thing about EXTIERIOR usage.
What I have asked for is simple I even made it easyer for you but in the end the bottom line is the word "EXTIERIOR"If it dont say it it aint so
Ross
Jun 15, 2004
14,693
I don't believe that there is any oil in walnut. Water will wet a freshly machined surface with almost no beading all glues adhere readily and well. Teak needs regular oiling to stay repellant. The primary advantage to teak is the it is not slippery when it is wet unless it has been varnished and the it is the varnish that is slippery.
Some wood species will always warp sweet gum being notorious. That wood will pull thw nails out and if you turn it over and renail it it will curl the other way. The ends of gum will rot off if they stay wet but the rot doesn't infect the whole board.
Aug 2, 2005
374
pearson ariel grand rapids
How about I’ll lower the bar for you show me a major yacht manufacture that uses walnut on the exterior of a hull as either as a structural component or as a trim.
I really doubt you'll find that example. Simply because Walnut would not be a strong selling point in advertising. What sells is teak and mahogany, not walnut or oak, or any of the other woods that have been used in boat building.
Don't have time to browse ads right now, but I've seen many references to 'teak finish' (often a way to call laminate something other than laminate), teak veneer, etc.
You won't find walnut, because for good walnut a manufacturer would have nearly the same costs, without the common appeal of teak.
You could have the best and most expensive marine wood possible, and many buyers would consider it inferior simply because they 'know' teak is the best marine lumber.
Ken.
Ross
Jun 15, 2004
14,693
Ken.
Public ignorance is also a factor. The amount of knowledge that most people have can be summed up by a statement made by one of my uncles woodworking friends, He said,"I know two kinds of wood pine and not pine". The variety of domestic hardwoods that are in demand all over the world is astonishing. Remember American oak in Europe is an exotic species. Here most wood workers don't know the difference between cherrybark oak and pin oak, but our ancestors did and they made the distinction when they selected wood for a project.
The reading of the wood species used in wagon construction is an education.
[D]​
[SIZE=+2]HAVE you heard of the wonderful one-hoss-shay,[/SIZE]
[SIZE=+2]That was built in such a logical way[/SIZE]
[SIZE=+2]It ran a hundred years to a day,[/SIZE]
[SIZE=+2]And then, of a sudden, it--ah, but stay[/SIZE]
[SIZE=+2]I 'll tell you what happened without delay,[/SIZE]
[SIZE=+2]Scaring the parson into fits,[/SIZE]
[SIZE=+2]Frightening people out of their wits,--[/SIZE]
[SIZE=+2]Have you ever heard of that, I say?[/SIZE]
[SIZE=+2]Seventeen hundred and fifty-five,[/SIZE]
[SIZE=+2]Georgius Secundus was then alive,--[/SIZE]
[SIZE=+2]Snuffy old drone from the German hive;[/SIZE]
[SIZE=+2]That was the year when Lisbon-town[/SIZE]
[SIZE=+2]Saw the earth open and gulp her down,[/SIZE]
[SIZE=+2]And Braddock's army was [URL="http://www.ibiblio.org/eldritch/owh/shay.html#brown"]done so brown,[/URL][/SIZE]
[SIZE=+2]Left without a scalp to its crown.[/SIZE]
[SIZE=+2]It was on the terrible earthquake-day[/SIZE]
[SIZE=+2]That the Deacon finished the one-hoss-shay.[/SIZE]
[SIZE=+2]Now in building of chaises, I tell you what,[/SIZE]
[SIZE=+2]There is always somewhere a weakest spot,--[/SIZE]
[SIZE=+2]In hub, tire, felloe, in spring or thill,[/SIZE]
[SIZE=+2]In panel, or crossbar, or floor, or sill,[/SIZE]
[SIZE=+2][/SIZE]
[SIZE=+2][D][/SIZE]​
[SIZE=+2]In screw, bolt, thoroughbrace,--lurking still,[/SIZE]
[SIZE=+2]Find it somewhere you must and will,--[/SIZE]
[SIZE=+2]Above or below, or within or without,--[/SIZE]
[SIZE=+2]And that's the reason, beyond a doubt,[/SIZE]
[SIZE=+2]A chaise breaks down, but does n't wear out.[/SIZE]
[SIZE=+2]But the Deacon swore (as Deacons do,[/SIZE]
[SIZE=+2]With an "I dew vum," or an "I tell yeou,"[/SIZE]
[SIZE=+2]He would build one shay to beat the taown[/SIZE]
[SIZE=+2]'n' the keounty 'n' all the kentry raoun';[/SIZE]
[SIZE=+2]It should be so built that it couldn' break daown![/SIZE]
[SIZE=+2]--"Fur," said the Deacon, "t 's mighty plain [/SIZE]
[SIZE=+2]Thut the weakes' place mus' stan' the strain; [/SIZE]
[SIZE=+2]'n' the way t' fix it, uz I maintain,[/SIZE]
[SIZE=+2]Is only jest[/SIZE]
[SIZE=+2]T' make that place uz strong uz the rest."[/SIZE]
[SIZE=+2]So the Deacon inquired of the village folk [/SIZE]
[SIZE=+2]Where he could find the strongest oak, [/SIZE]
[SIZE=+2]That could n't be split nor bent nor broke,--[/SIZE]
[SIZE=+2][/SIZE]
[SIZE=+2]That was for spokes and floor and sills;[/SIZE]
[SIZE=+2]He sent for lancewood to make the thills;[/SIZE]
[SIZE=+2]The crossbars were ash, from the straightest trees,[/SIZE]
[SIZE=+2]The panels of whitewood, that cuts like cheese,[/SIZE]
[SIZE=+2]But lasts like iron for things like these; [/SIZE]
[SIZE=+2]The hubs of logs from the "Settler's ellum,"[/SIZE]
[SIZE=+2]Last of its timber,--they could n't sell 'em,[/SIZE]
[SIZE=+2]Never an axe had seen their chips,[/SIZE]
[SIZE=+2]And the wedges flew from between their lips[/SIZE]
[SIZE=+2]Their blunt ends frizzled like celery-tips[/SIZE]
[SIZE=+2];[/SIZE]
[SIZE=+2]Step and prop-iron, bolt and screw,[/SIZE]
[SIZE=+2]Spring, tire, axle, and linchpin too,[/SIZE]
[SIZE=+2]Steel of the finest, bright and blue;[/SIZE]
[SIZE=+2]Thoroughbrace bison-skin, thick and wide;[/SIZE]
[SIZE=+2]Boot, top, dasher, from tough old hide[/SIZE]
[SIZE=+2]Found in the pit when the tanner died.[/SIZE]
[SIZE=+2][/SIZE]
[SIZE=+2]That was the way he "put her through."[/SIZE]
[SIZE=+2]"There!" said the Deacon, "naow she 'll dew."[/SIZE]
[SIZE=+2]Do! I tell you, I rather guess[/SIZE]
[SIZE=+2]She was a wonder, and nothing less![/SIZE]
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
I often refer conversationally to the "Deacon's One Hoss Shay." I often get blank stares in return. But then, I often get blank stares anyway.
BTW, the Deacon tied his horse to the shay using a bowline... It, too, lasted 100 years.:eek:
May 23, 2004
3,319
Wow....Just Wow.
Give me Fiberglass and Stainless Steel any day. Teake looks nice but it is a PAIN IN THE ARSE. Any wood requires more maintenance!
Jul 1, 2007
169
hunter 29.5 Nanaimo BC
I have seen walnut fenceposts in ont canada, when I used to work on farms as a kid.
The farmers used what they grew.
Did not know it was poisonous for horses though.
is that exterior enough.
