Since most of us have a mast and keel it would seem to me to be pretty ease to connect a very high resistance volt meter between the two and see the potential build up. Mr. Tesla apparently did such an experiment when in Colorado and said he could see the energy passing overhead. Certainly will not prevent a strike but could give an indication of one approaching (or not).
If that worked an enterprising young man could build a circuit that sounded an alarm when the potential "became dangerous", sell it to the uninformed and buy a bigger boat.
Thoughts?
This is actually a good idea, and something that I have been considering for the past year.
Last summer a storm unexpectedly changed course and instead of passing east 15-20 miles to my north, turned due south and came straight at me while at anchor off of Lloyd Point of Lloyd Neck, Long Island. When it was about 8 miles away I went up to the fore deck to check the anchor and noticed a humming sound similar to when you are standing under high voltage power lines. When I got near the standing rigging (about 18 inches or so) my hair started to stand on end, and when I was about 6-8 inches away, a strong tingling feeling all over my arms was felt.
Having flashbacks to peoples recounted tales of having their boats struck by lightning I recalled that people near the standing rigging often reported felling a tingling sensation from the standing rigging in the moments before the strike occurred (assuming they were near it). I reached out and touched the fore stay to make sure I wasn't imagining things, and received possibly the worst static shock I have ever experienced in my life.
I immediately told my GF to get below deck and to stay away from the chain plates or the compression post and I pulled the anchor up as fast as humanly possible, started the engine, and shoved the throttle to the limit.
My theory was that a charge was building around the boat, possibly coming through the lead keel, maybe the anchor, maybe both, and going up through the standing rigging (my mast is grounded to the keel) and building a highly charged mass of air around the boat, using the mast and rigging as a transmitter of sorts (earth science 101 teaches us that the lightning bolt usually starts at the ground and moves up to the cloud to equalize a charge imbalance between the ground and the clouds).
My theory was that I could reduce my risk of what was otherwise likely about to be an imminent lightning strike by A) quickly move away from the highly charged air mass that had been building around my boat while at anchor. and B) get as much air to flow over the mast and standing rigging as possible to dissipate the charge that had built up, and to do so across as wide of an area as possible to prevent another "hot zone" from forming around me that could give birth to a lightning strike.
I don't know about the humming sound as it was immediately drowned out by the sound of the engine, but the tingling feeling coming being near from the standing rigging started to fade within 30 seconds or so after getting the boat moving, and within 2-3 minutes it was completely gone, so I believe I analyzed the situation and reacted correctly, and most importantly, my boat did not get struck by lightning.
I'm certain that in that situation some sort of electrical potential monitor attached to the mast would have clearly given me a warning that the vessel was rapidly building a large charge, which was putting me at an extremely high risk of being struck in the very near future, and it would have done so long before I was able to notice the humming sound, or the tingling feeling from the standing rigging.
