Did Catalina ever build a swing keel 25,27,28
biiggd
Jul 4, 2010
20
windrider 17 CLT
I am actively interested in buying an older Catalina 25,27,or 28 foot boat. I HAVE to have a swing keel. Am I out of luck, or did Catalina ever build a swing keel in their older 25,27, or 28 foot boats. Thx for the help!
May 21, 2006
321
catalina 25, 30 montauk / manhattan
i have an 86 25 with swing keel. just replaced the winch and cable last year.
have had boat for about 5 years and have replaced just about everything you can imagine. recently bought a cat 30 and although haven't tried yet was thinking about selling the 25. not sure where you're located but let me know if want to discuss.
dane
biiggd
Jul 4, 2010
20
windrider 17 CLT
CAT 25 Swing Keel
dane
Thx for info on Swing Keel CATALINAS. Am located in NC. Need a swing keel for trailering to the coast. I live 5 hours from the coast. Would u consider taking the 25 off shore occasionally? )Max 3 miles while outside the Inter Coastal Waterway South Bound from Wilmington to Florida. Seems all the boats in the Catalina class are glued and riveted together. Whether Hunter, C&C, etc...same/same. Just the nature of the breed for the price range I guess. How much are u wanting and where are you located? Any pics? Thx, Richard
OldCat
Jul 26, 2005
728
Catalina , Nacra 5.8, Laser, Hobie Hawk Wonmop, CO
Go Out
Would u consider taking the 25 off shore occasionally? Max 3 miles while outside the Inter Coastal Waterway South Bound from Wilmington to Florida.
Built by Catalina, to go to Catalina;). That is a bit of humor, but since Catalina is 20nm or so out from LA harbor, you get my point. More important than 'how far out' is how far from a safe harbor you are and your comfort level regarding the weather forecasts. In your area, you need to watch for thunderstorms and winds whose direction is against the Gulf Stream, in addition to the more obvious big storms.
You don't need offshore construction for coastal sailing, which 3 miles out generally is unless you have a long rough coast with no harbors.
If I had time to go to California, I would happily take my 22 to Catalina:D. I don't know your waters north of Miami, but C25s go more than three miles out 'all the time':).
OC
biiggd
Jul 4, 2010
20
windrider 17 CLT
Re: Go Out
Thx very much for the advice! Would u take a Catalina 25 across the Gulf Stream to the Bahamas in good weather? I have always heard to never take a "glued together" boat very far off shore. Thx! RJ
biiggd
Jul 4, 2010
20
windrider 17 CLT
Thx@ Do the swing keels get jammed with crude, barnacles, etc. if left in salt water or would a wing keel boat be less maintenance? RJ
OldCat
Jul 26, 2005
728
1. Beyond my experience. My few experiences with the Gulf Stream have been in larger boats (40') or smaller (Hobies). I was dismasted on a resort owned Hobie with the wind against the stream. Even on a 40'er the boat can bounce around a lot. But how small to go across is not something I am comfortable answering.
2. The swing is more maintenance. The cable, winch, lockdown bolt and the bearings all need to be looked after. More moving parts, more problems. Make sure the system is well protected by zincs.
Best o' Luck
OC
What utter nonsense. "Glued together?" Where'd you get that?
Stephanie, The Boat Babe and her guy sailed their B25 to the Bahamas and back. No one goes across the Gulf Stream with a north wind. The C25 Association website is a valuable resource (http://www.catalina-capri-25s.org/forum/forum.asp?FORUM_ID=3) and there are guys there who have sailed there.
biiggd
Jul 4, 2010
20
windrider 17 CLT
Stu, according to the pics and script providedby the factory the Catalina hulls are joined to the upper deck with rivets and glue...as are most boats in this price range. I don't know this for a fact, but I believe it to be true as this is the way the factory presents the boat. Thx!
biggd, the hull to keel connections are bolted not riveted beneath the rub rail on the three Catalinas I've owned.
Glue? 5200 is hardly "glue" - it's pretty tenacious stuff, which is why I keep saying the only place it has on a boat IS the hull to deck joint.
biiggd
Jul 4, 2010
20
windrider 17 CLT
Thx for the clarification! I do know that the hull to keel is through bolted but I was referring to the hull to upper deck being riveted and glued together as per the factory. I am not knocking the boats at all. They are some the most beautiful boats ever. I only wish that I could afford one@
Aug 18, 2010
6
Catalina 25 Santa Cruz Yacht Harbor
So we've got this Catalina 25 and I keep hearing about "lock down" BOLTS. What's the use of a swinger if it's locked in the down position?
I have some concern that "if" we get a bit too far over and the keel breaks free of its watery confines and we lay it down, that the keel will begin to fold up. We'd then lose our ballast advantage and things could get a bit sticky.
Wonder if any of those Catalina 25 swing keel folks who read your post have any first hand knowledge of laying one over. All those posts I've seen elsewhere only refer to something other than a Catalina 25. I'm beginning to think they don't go over.:D
