swim ladder
hz293
May 29, 2009
24
Catalina 27 Kalama, WA
I am a big guy and if I went overboard even at the dock, there is no way I could get back on either the boat or the dock. I have a Lancer 25 with the transom slanted forward. I would need to be able to deploy the ladder from the water. Suggestions please on what solid swim ladder you have or would like to change to or modify. Also, what deployed depth do you suggest From reports I have read, the rope type emergency ladders are not good.
Harris
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
My ladder is hinged at the bottom and there is a rope that hangs down to allow me to pull it down.
caguy
Sep 22, 2006
4,004
This was covered here recently.
In terms of depth, my wife and I found that there should be at least 2 steps in the water.
I agree I have a hooked gunnel ladder that only extends down one rung below the surface and I can not get back in using that ladder, besides I would have to remember to deploy it before I accidentally fall in.
This one I can reach the rope that is looped and hooked on the fairlead from the water. If I couldn't reach it I would use a highway mans knot that could be pulled loose from the water. This telescoping ladder was $25 on ebay.
6,370
Catalina 320 Barnegat, NJ
My wife bought the hinged ladder from West Marine and it has worked very well. There are 2 mounting fixtures that I attached to the gunnel. They are very secure so that the ladder feels like a permanent fixture, but it is easily removed. My stern also slopes inward so the ladder does not hang straight down. I cut the aluminum stand-off feet as short as I could so the ladder clears the bottom of the stern, but it is still angled slightly. This does cause a problem because the flimsy rubber gaskets that are supplied will disintegrate easily, especially with the leverage when standing on the bottom rung. However, I was able to find a very hard plastic gasket that with a little trimming, fits inside the stainless steel tubes and provides a very secure fitting so that the tubes do not pinch together when the ladder is deployed. I have only needed to replace them once in 5 years and they are still in great shape now. We use our ladder a lot because we do a lot of swimming off the boat. The dog even climbs up the ladder on her own.
We have 3 rungs in the water (3 in and 3 out if I'm not mistaken). For us, not having a solid ladder would be a big problem. Ours has worked perfectly well and we have not had to go to the expense of a custom fit so we are very satisfied.
The hinge is basically at the waterline, so when healed, a corner of the ladder at the hinge causes some turbulence at the stern. If we raced, I would remove the ladder for a cleaner line.
With the hinge at the waterline, I can pull the ladder down when I am in the water easily without the use of a rope. However, when I am in the boat, I have to reach down to the waterline to pull the end up out of the water. This could be done much more easily if I fixed a rope for hauling the ladder up, but I haven't done that yet.
Nov 22, 2008
3,562
Endeavour 32 Portland, Maine
One of the most important, and rare, pieces of safety equipment there is for anyone who ever cruises alone. Even with crew or guests on board, in waters as cold as Maine, the ladder could be the difference between life and death within minutes.
Jan 2, 2008
547
Hunter 33 (Cherubini design Forked River, Barnegat Bay, NJ
The older we are (notice I didn't say "YOU") the more steps we need in the water. Windline which makes many of the West Marine ladders are nice, but rarely put more than 1 or 2 steps in the water. Dive N Dog makes nice ladders also and has a slightly better selection. It seems to me I installeed one of the West Marine / Windline 2 plus 2 folding "removable" ladders on the transom of my Lancer 28, which is pretty much the same boat as your 25. It had a plastic latch which allowed the ladder to be pulled down from below if one were silly enough to neglect deploying it on the way down. Mine was permanantly mounted by bolting straight through. Make sure your installation provides for comfortable, strong handholds so you can actualy haul your self out. West curently has the 2 plus 2 on sale.
Sam
Apr 11, 2010
982
Hunter 38 Whitehall MI
The first owners of our previous boat a Catalina 34 had a custom made boarding ladder because he too was apparently a large man. It was made by a company called Railmakers. It was your standard boarding ladder with a second section added and was hinged so that it folded on itself. When fully extended it went a full 3 steps below the water. No one ever had trouble boarding with it.
Only problem to watch our for is with that traditional ladder configuration the rope technique to pull it down could cause it to crash on a person in the water as it swung down
