Thought I had all the problems found, and all the fixes figured out. This morning installed a new cutlass bearing. Not really needed, but the boat was out of the water, and the rudder was off, which of course is necessary to pull the shaft. Not going to miss the opportunity to keep from having repeat this little exercise again in the forseeable future. Stuck the shaft back in, and noticed the shaft log was paper thin on the bottom.:cussing: Apparently a motor mount has failed, or moved or something. Installed a new dripless seal not quite two years ago, and didn't notice anything at that time. The shaft log clearance is pretty snug, and the log pretty thin. So now I have to do something with the shaft log. It is 1 & 1/2" OD, and my thought is to slide a piece of 1 & 1/2" schedule 40 PVC down over it, with LOTS of 5200. Will have to change the bellow, and do whatever with the motor mount and alignment, but is the best I can come up with so far. Anyone have any better ideas, or am I nuts to try this. If your gonna tell me I'm nuts, then have a better idea.
