Oday 26 bow gasket near bow-tow-ring
8
Oday 26 Forked River
Hope you understand, my Oday 26 has a black gasket 'hole' slightly above the
bow-ring where the trailer-winch-hook grabs it. Any idea what and why? I see the
nav light on the bow-pulpit. please advise to this new owner of a Oday 26
Thank you
Daniel
Forked River,NJ
Bobalu Lil'Ann
1985 Oday 26
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
Thank you
Daniel
Forked River,NJ
Bobalu Lil'Ann
1985 Oday 26
I don't ever remember seeing an O'Day 26 with an anchor locker, but maybe your 26 has one and what you are seeing is a drain for it. Perhaps the previous owner installed it. This is something that you're going to have to investigate from inside the cabin V berth section. Good luck with the O'Day 26, they're a nice little boat.
Dec 8, 2006
1,085
Oday 26 Starr, SC
O'Day 26 Anchor Locker
Right. If you have an anchor locker then it's the drain hole.
Rich
I think that you will find all O'Day 26 have anchor locker with drain. The drain is clearly visible in locker and hose to hole can be seen by removing plywood from front of V-berth - about 8 screws.
Both ends should be sealed ( I do not use the word caulk ) because ordinary callking is best based on my past experinece. I now use NP-1, a roofing one part polyureathane sealant which works well )
Ed K
26
89
Oday 26 Lake Keowee,SC
I know this is late BUT look at this picture of my Oday 26 1985 and you can clearly see the anchor locker drain. I hope this realy helps.
