I also asked this in the head mistriss forum - but it seem quiet over there so asking here as well (apologies if this is a problem...)
The boat is torn apart and I want to get it back together sooner rather than later !!
I am installing a PHC-LBA conversion kit that I purchased from SBO.com.
I have a question about the installation of the old (Jabsco ) bowl on the new PHC base.
The schematic diagram supplied shows the bolt (part F081) coming up thru the new base, passing thru the Bowl Gasket (Part 1234), and has a "nylon shoulder washer" (part RNI) that seems to be shown on the drawing as being on top of the Bowl Gasket. But the diagram does not show the bowl....... WHERE EXACTLY DOES THE RNI nylon shoulder washer GO IN RELATION TO THE BOWL ???
Is this "nylon shoulder washer" supposed to be on top of the Bowl Gasket - but BELOW the bowl ? (as in - sandwiched between the bowl and the gasket ?)
Or is is supposed to be between the top of the bowl and the Nut (part 1226B) ??
I see 2 options for the stacking of the parts: (top down order)
OPTION 1:
Nut (1226B)
Nylon shoulder washer (RNI)
Bowl (old Jabsco Bowl)
Bowl Gasket (1234)
Base (1301 PW)
Bowl Bolt (F081)
OPTION 2:
Nut (1226B)
Bowl Gasket (1234)
Base (1301 PW)
Bowl Bolt (F081)
Can anyone clarify this for me ???? I am stumped on this one and the supplied schematics totally ignore the bowl in all diagrams....
Thanks,
Paul
OPTION 1:
Nut (1226B)
Bowl Gasket (1234)
Base (1301 PW)
Bowl Bolt (F081)
OPTION 2:
Nut (1226B)
Bowl Gasket (1234)
Base (1301 PW)
Bowl Bolt (F081)
Thanks,
Paul
