Maintenance of Furler
wonbae
May 23, 2010
4
Beanateau Oceancu 321 Portsmouth, RI
My Benateau 321 has a Profurling system, and nothing has been done since the boat was new(1996). I noticed in recent years it is increasingly hard to furl in. Is there any lubricating parts I missed? Thanks.
Won
Jan 10, 2009
590
PDQ 32 Deale, MD
Won
Lime can build up. Bearings can corrode or fail (particularly plastic after 14 years). If metal bearings, lubrication is good.
Mine explode on a cruise, which was inconvenient. I would get a copy of the manual, open hr up, and have a look. I doubt the problem is going to get better, only worse.
The rebuild (see below) was not difficult or expensive, and life is better now.
http://sail-delmarva.blogspot.com/2009/09/hood-seafurl-800-bearing-replacement.html
2,288
C30 Event Horizon Port Aransas
Won
Take the sail off. Check the swivel to make sure it is still moving freely. Spin it by hand just to see if you can feel any resistance that is not normal.
Do you know what model you have? Do you have any pictures of it?
wonbae
May 23, 2010
4
Thank you for your information. The Beneteau factory sent me a copy of manual and states that nothing is needed.
Won
