missing port dogs
2
Hunter 30 Baltimore
Just bought a 1980 Cherubini Hunter last season. One very odd thing. All the dogs for the portlights are missing. Will be replacing the salon ports but would like to find dogs for the other small ports as they are still serviceable. Know that I can get them for 7.00 a piece on the Hunter owners website. Just want to know if anyone could obtain from a salvage.
Benny
Sep 27, 2008
1,149
Hunter 320 Tampa, FL
That is the same price the manufacturer here in Tampa is listing them for. Recommend you get new ones.
Jun 21, 2007
2,117
Bummer that a PO sent the dogs on a walk-about. But I do know (from the condition of many of the ones on my boat when I bought it) that the original knobs' plastic cracked away from the inner threaded brass bushing.
If you referring to the female knobs, and your are on a budget, another option is 1/4" x 20 stainless steel wing-nuts. Put down a SS washer first between the port plastic and the wing-nut. If all the "knobs" are converted to wing nuts, the overall visual effect isn't bad.
So how are the ports kept closed now?
Dec 2, 1999
15,184
The older ones had metal inserts. They caused the knobs to crack. The newer ones are all plastic and are a lot more serviceable.
Jun 21, 2007
2,117
Correction to Wing Nut Size
At my boat yesterday, the Gray ports dogs and nobs were larger than the 1/4" that I posted before. :eek: I didn't have a 5/16" bolt handy to compare. Best you make you own determination if you did decide to go the wing nut option.
Sorry.
Jun 3, 2004
27
Hunter 27_75-84 welaka fl
Re: Correction to Wing Nut Size
5/16x18, And studs can be made from stainless bolts.
Jun 25, 2009
542
Hunter 33 Seabrooke, Houston
How many do you want?
There are a lot on this salvage yard
I think I can get them for $1.00 each
Let me know, send a picture to make sure they are what you need
Jorge
Jun 10, 2004
135
Hunter 30_74-83 Shelburne
I make my own when they break, like the others said, out of SS wing nut and washers. When the threaded parts break, those are a little harder- start with a SS bolt the right length, cut the head off, drill it for the pin. You'll definitely need at least a vise and sharp ***** punch and unless your very steady, patient and have a very sharp drill, you'll need a drill press.
Update: I've been censored! Like George Carlin said: You can say I pricked my finger, but you can't say I fingered my...
