The manual Bilge pump does not work in the O'day 25 that I just purchased. Feels like it is not primed. Pictures attached. The pump exits into the sink drain out the through hull for the bathroom sink.
Here are some questions for anyone that might be able to share some info:
Is it normal to exit pump to sink drain?
The sink drain and the bilge pump is put together with a bunch of clear poly hoses and clamps. While this system does not leek when using the sink, Is adequte to hold a good prime for the pump?
I am not familiar with this type of pump, is it re-buildable?
If I add an electric bilge pump, can I just add another hose to all of these poly hoses and use the same through hole exit?
wow alot of questions, I am a rookie, but I really want a bilge pump system that works dependably!
