New Name
92
Tartan 30 Bayfield, WI
Hi Everyone...
I just recently purchased a beautiful new boat, she is a glossy white fiberglass sailboat. The previous owner had named her after his family members. Now it was a beautiful name for him, but it just doesn't fit my style. So, logically, I wanted to re-name the boat.
I, ever so carefully, removed the current name and wet sanded the gel coat and then polished and buffed the gelcoat, however there is still a faded yellow shaddow of the previous name. How do I get rid of this without eating through the gelcoat?
I would not consider myself an expert boat mechanic, so the easier the solution, the better.
Thanks
-Abe
Sep 29, 2008
1,981
Catalina 310 #185 Quantico
Get a bigger graphic
The gelcoat may fade over time, but it won't be anytime soon.
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
That old name will fade in a year or two to the point you can't see it easily. to the discerning eye, it will always be there. Consider it the soul of the boat before you got it. Be sure to use the necessary name change ceremony.
PaulK
Dec 1, 2009
1,541
Sabre 402 Southport, CT
Higgs is absolutely correct. The old name will NEVER fade away unless your namechanging ceremony is properly executed. You do not want to mess with Neptune! Liberal amounts of Mount Gay worked well in our situation, though you may find something else local to Illinois (corn liquor?) may be just as good. We used rubbing compound (Finesse-it is a bit less rough than the standard stuff in the wide, short can) to remove the old name.
Dec 14, 2008
92
So, this leads to the next question: what is the proper tradition and course of events constituting a name changing ceremony?
RECESS
Dec 20, 2003
1,509
Catalina 27 . St. Mary's Georgia
Renaming ceremony
I was lucky enough to buy a 1980 sailboat from a woman who never gave it a name. I did sail her backwards the first outing just in case. It was more like drift her backwards, but it was the best I could do.
