I will check again tomorrow.Ross - computer fan draws 0.18 AMP not 0.018AMP. It is a good solution when placed on the companionway doors. Why did I not think of that!
That gave me an idea. How about fans mounted in one of the hatch boards, with contacts mounted and wired to the boat, so when the hatch board is in they make contact and start running off of a converter so it doesn't drain the batteries and only runs when shore power is hooked up?Ross - computer fan draws 0.18 AMP not 0.018AMP. It is a good solution when placed on the companionway doors. Why did I not think of that!
I checked this morning and got .033 amps higth speed and .009 amps on low speed.I will check again tomorrow.
A fan will move more air if it supports the normally-occuring air convection, so I would guess that removing heated air from the top of the cabin is most efficient. Also, I believe warm air is capable of carrying more water vapour than cooled air. Finally, an exhaust fan on top of the cabin is probably assisted by any passing breezes, while a fan exhausting lower down would not be. (how's that for over-thinking something...)Ross said:This [idea] is prompted by mildew and moisture; not comfort. All those problems are low down in the boat so wouldn't it make sense to pull air out of that area?
... and the current draw and noise from computer-type fans drops even more if you run them at less than their rated voltage... eg connecting two 12 fans in series, on 12 v.I checked this morning and got .033 amps high speed and .009 amps on low speed.
I want to install a computer fan to ventilate my bilge. Where to I get them, and what specifically do I want to buy (specs, models, etc.)? Any suggestions would be appreciated!My three inch computer fans draw .018 amps at 12 volts and move 24 cfm.
I scavange them from old junked computersI want to install a computer fan to ventilate my bilge. Where to I get them, and what specifically do I want to buy (specs, models, etc.)? Any suggestions would be appreciated!
I agree with sailingdog. Nicro makes good vents, but steer way away from Sunsei. You will just end up with a hole in your boat that is a different size hole than a Nicro model. They are horrible.I'd point out that the Nicro vents do actually work quite well if installed properly. The temperature in the cabin on my boat dropped about 15˚ after I installed it. When I installed the second one, it dropped another 10˚ or so.
