What's wrong with this idea?
Ross
Jun 15, 2004
14,693
Ross - computer fan draws 0.18 AMP not 0.018AMP. It is a good solution when placed on the companionway doors. Why did I not think of that!
I will check again tomorrow.
2,288
C30 Event Horizon Port Aransas
That gave me an idea. How about fans mounted in one of the hatch boards, with contacts mounted and wired to the boat, so when the hatch board is in they make contact and start running off of a converter so it doesn't drain the batteries and only runs when shore power is hooked up?
DannyS
May 27, 2004
933
Beneteau 393 Bayfield, Wi
Interesting idea Hermit, let me know how you keep the contacts from getting wet since keeping water out of the cabin is the job of the hatch boards. ;)
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
Ross said:
This [idea] is prompted by mildew and moisture; not comfort. All those problems are low down in the boat so wouldn't it make sense to pull air out of that area?
A fan will move more air if it supports the normally-occuring air convection, so I would guess that removing heated air from the top of the cabin is most efficient. Also, I believe warm air is capable of carrying more water vapour than cooled air. Finally, an exhaust fan on top of the cabin is probably assisted by any passing breezes, while a fan exhausting lower down would not be. (how's that for over-thinking something...)
I checked this morning and got .033 amps high speed and .009 amps on low speed.
... and the current draw and noise from computer-type fans drops even more if you run them at less than their rated voltage... eg connecting two 12 fans in series, on 12 v.
Last year I found a car solar vent similar to this, for less than $10 at a clearance sale. I'm thinking of putting a small notch in the upper hatchboard to allow mounting this thing. It might be enough ventilation to keep some air moving, without seriously compromising the function of the hatchboards. Probably only suitable for a small boat.
Sep 29, 2008
1,980
Catalina 310 #185 Quantico
What about this vent?
Did see some comments from the RV crowd that this works great. But we don't typically do 60 mph. Could Roger use this with a PVC adapter to put on the top of his chimney?
I have actually been thinking of getting one of these and replacing the teeny tiny vent on my holding tank with this (under my port stern perch seat) and putting a larger vent hose on it.
http://www.campingworld.com/shopping/item/cyclone-sewer-vent/31992
806
Treworgy 65' LOA Custom Steel Pilothouse Staysail Ketch St. Croix, Virgin Islands
Which Computer fans, from what source?
My three inch computer fans draw .018 amps at 12 volts and move 24 cfm.
I want to install a computer fan to ventilate my bilge. Where to I get them, and what specifically do I want to buy (specs, models, etc.)? Any suggestions would be appreciated!
Jul 25, 2009
270
Catalina 1989 C30 Mk II Herrington Harbour South, MD
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
Had a boat with no ventilation and one with dorade boxes. The Dorades are highly recommended. The holes in the Dorade boxes are a perfect fit for a solar fan so while a bit ugly I put a solar fan in one as an exhaust and the other is the vent. That way on a hot day with no wind the ventilation keeps moving air. So far has worked quite well.
Ross
Jun 15, 2004
14,693
I scavange them from old junked computers
JeanV
May 2, 2010
1
Manta Manta 40 Wrightsville Beach
I'd point out that the Nicro vents do actually work quite well if installed properly. The temperature in the cabin on my boat dropped about 15˚ after I installed it. When I installed the second one, it dropped another 10˚ or so.
I agree with sailingdog. Nicro makes good vents, but steer way away from Sunsei. You will just end up with a hole in your boat that is a different size hole than a Nicro model. They are horrible.
