I am making a new table for the cabin. The original one was heavy, to big to easily get around and not easy to put away.
This one is about a foot shorter and 4" narrower. It is semi-permanently mounted to the bulkhead where the original table was. It folds in half. While it's folded in half the table has fiddles. When it is opened it is flat, and the fiddles will be facing down on that opened half.
The table is formica on 3/4" plywood. The outter rails are teak screwed on. The hinges in the pic are the ones I ordered. They are 4" long and will open 360 degrees(so they don't support themselves).
Does anyone have flush table hinges? or ever installed any? How is the table leaf usually supported?
To make the hinges flush, what is the usual method for cutting the grooves for them to sit down in? I guess I need to know how are things usually inlaid in a table top?
Just to be a little clearer, the two hinges will be inlaid on the centerline of the table top in the third picture. Allowing it to fold and look like the table in the second picture.
