Interesting.. My buddy (his other boat is a Cherubini Hunter 33) noticed a badly neglected 27’ Stiletto catamaran a couple of blocks from his house.. He ended up buying it for less than $2500 so he and I are getting the thing sorted out and assembled. It is quite a project to set up on the trailer prior to sailing; my guess is about two-three hours for two guys.. maybe less after some practice. Boat is in pretty good shape but the starboard “canopy” has been gone for some time and the interior of that hull is water damaged.. We are thinking of using the remaining canopy as a form to make a glass lay-up new one if we can’t find a used one somewhere.. Interior is pretty simple and there is enough left of the old wood to use as patterns .. Came with 5 useful sails and a Yamaha high thrust, electric start 9.9 four stroke.. Should be a fun boat to sail .. Yesterday while trying to get the electric starter to work, we noticed the hot electric smell and found a melted spot in the wire connecting to the engine.. A small nick (1/8”) in the cover had let salt water inside and corroded the copper to a brittle red/black material that was apparently not much good as a conductor.. Splicing that today.. another reason to not use an outboard.. We may get the mast up today.. Haven’t found any cracks in the standing rigging swedges and all the wire and rod looks good.. I think he got a deal..
Factory will still make parts ..
Anyone have any used parts for this thing?? Anyone have info to share?
