Should I worry about sanding and putting a coat of ablative paint on the spots where the jackstands presently cover?
You could always leave them bare. Then when out sailing, you always know where you can find some fresh sea life for a snack.Should I worry about sanding and putting a coat of ablative paint on the spots where the jackstands presently cover?
Put ANOTHER one next to the one you need gone, THEN take away the old one.The jackstands one at a time just use a little care when you do it.(assuming there are 2 per side and one under the bow.)
Tom s/v GAIA
I have never noticed those spots to be any worse over time. This is a very common request. I've done it at least a dozzen times.Should I worry about sanding and putting a coat of ablative paint on the spots where the jackstands presently cover?
