Does anyone have a basic diagram or pics to rig a Catalina 27 for solo sailing
How long have you had the boat?Does anyone have a basic diagram or pics to rig a Catalina 27 for solo sailing
This is nice, but 6 lines, each side is over my head at this point,Buzz, here's a link to a setup that demonstrates the other extreme. You might want to check out the other mods this couple have done on their boat. I'll be getting my C27 soon. We might want to get together to collude and commiserate.
http://www.blumhorst.com/catalina27/cabintop-lines-aft.htm
I agree Buzz. I have four coming back on mine. The Main Halyard, the ezjacks, the furler line, and the toping lift. Before I had the furler I had a jib halyard and a very necessary down haul for the jib.This is nice, but 6 lines, each side is over my head at this point,
If you have a good autopilot, there is no need to hoist sails from the cockpit.Thank you, it makes alot of sence, I have only had the boat one year. I had thought if I could raise the Main and Jib I could set sail on my own. I normally sail with my wife, but also seek some solitude. Thanks for yor comprehensive insight
Look at displacement not boat length.How bout a good reccomendation on a sweet tiller pilot. You have sold me!
The Raymarine ST2000+ is rated for 10,000 pounds ... the minimum I would consider for a C27 Retail $730
The X-5 is rated to 13,200 pounds and Retail is $1280
Navico is now Simrad the TP22 rated to 5 tons displacement might be a good choice too.
Street prices for the TP22 are in the $460 range ... $600+ for the Ray ST2000+
If you only use the pilot in mild conditions a smaller unit will serve well. If you want the pilot to steer whilst sailing go bigger.
I really liked the Navico/Simrad pilot on a 26 footer that only weighed 3500 pounds. You can guess how long it lasted on the C30. I went up to the recomended size, blew the screw drive out twice (repaired under warranty) and gave it the float test after the third screw drive failed (they don't float). It had decided to give up while I was on the foredeck changing sails ... mutinous crew has to swim for it on my boat ... :cussing:
I now have a ST4000 that uses the same drive as the X-5 and it does a pretty decent job ... it has never failed in 6 years and steers well to GPS or Wind when conditions are boring. It tries when the boat is loaded up, but it is just not "smart" enough to to the job. Plenty of power and speed, just software limited.
I freely admit that I tend to work my pilots pretty hard, so take that into consideration ... it is your money I'm spending!
I happen to like Raymarine stuff and I know I pay a premium. The newer Simrad tiller pilots might be better than the ones I had. For a $160 savings, I'd look for feedback from a Simrad owner. That might well be the best deal.
Randy
