Boarding up ports
higgs I like the way your boats ports are. I want the 6 ports I am replacing to look similar to yours. Though I may only put 4 if I can make it look right.
Then you shoulda bought a Nassau 34, hermit. If you want New Found Metal ports in your cabintop, then a CS-t 36 would work, too.
higgs wrote: "Someday you will want to sell that C30. If it is noticeably different looking that the norm, your selling price will suffer. "
He's right, but if you are going to keep your boat forever, then it shouldn't matter at all.
You simply will have the most distinctive C30 cabintop known to mankind.:)
It's very hard to make a MacGregor into a Pacific Seacraft.
Sorry, it's merely impossible.
Ross
Jun 15, 2004
14,693
When a boat gets to a certain age you can remodel it to suit yourself and as long as you don't get to extreme you will still have a boat that buyers will desire. I have extensively changed my Islander 30 inside and outside and still get an offer about once each year but she is not for sale.
Timo42
Mar 26, 2007
1,042
Venture 22 Marina del Rey
"You can't make a racehorse out of a pig...but you can have a very fast pig":D
But the trick is knowing when to stop.
2,288
C30 Event Horizon Port Aransas
As soon as I get these new port lights installed, I am trading it in for a nassau 34.
Nov 6, 2006
10,253
Hooo Yaaa Isn’t there a pretty good curve in the cabin side where the fixed lights on the C 30 are..?? Going to be tough to fit standard opening ports to it?? I dunno… I usually don’t need the extreme dark unless I’ve been discussing MainBrace Splicing with my buddy Sailor Jerry !!!
2,288
I guess he wasn't going to be happy until he had standing headroom, no matter how many stories it took.
Sep 29, 2008
1,981
Catalina 310 #185 Quantico
A little humor
Ed, yes I was going to board them up glass them in and make it darker in the cabin. ... I don't like that much light in the cabin either. I would like smaller ports with dark tint. My apartment I built upstairs in my shop doesn't have a single window either. I like to be able to make it very dark.
Hermit, Saw this post and was really thinking it would be smarter like a few said and just dremel out a little bit around the edges and re-glass with some chop/strand and epoxy.
Your comments above reminded me of this #3 on this link http://www.trolinger.com/david/simulate.html although it is a little different from what I remember.
2,288
There was a deluge here so I couldn't start on it. But it's supposed to be clear tomorrow. I am going to attack the side of the boat with a router and probably a 4-1/2" grinder(it always seems to be the appropriate tool for any job).
I don't know how difficult the curve will be to fill with plywood. I may have to cut relief cuts to the plywood and then fill all that with epoxy. I have these pieces of ABS I am going to use to hold the epoxy in place and try to get the surface to be pretty smooth with out too much sanding and filling.
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
I don't recommend this for the following reason
Certain things like to grow in dark humid environments. Most of tem belong to the fungi family. Your project will soon have enough growth as to provide long term sustenance on your voyages. Make sure you have enough ventilation on this boat during your absences.
2,288
I have been leaving a fan running. In the washboards there are slits for ventalation. But I need a real solar ventelator.
