Hello all
We are new to sail boating. We have been boating for over 20 years. To give you an idea of our experience level we currently own a 1985 Hatteras MY and we have taken her through the Erie Canal, across Ontario, and up to 1000 Islands twice. We've done the Champlain Canal system to Lake Champlain (never met Champy tho) and gone as far as Block Island on the L.I. Sound. Last year we took Freedom South on the ICW and then Wintered over in the Abacos.
All along I have been maintaining and upgrading Freedom myself. This includes removal and installation of a transmission at 400 lbs. So I consider myself a bit mechanically inclined. By profession we were both software engineers, however I hold a B.S.E.E. which I no longer practice and have basically forgotten.
Too many Grabbers and Nippers I suppose.
So we've been around a bit.
I use Nobeltec software for planning, and have been downloading updated charts from NOAA.
About the only sailing experience I can claim is on a 16 foot Hobie years ago. Along with this I do ok in a Sailfish and Laser having had to be towed back only once. If going out on various snorkle trips in the Caribean counts for experience we have some of that also but I suspect that lines up with the Nippers/Grabbers line. Here and there folks have let me pilot their sailboats but this usually occurs after all of the sails are set.
So anyway,
We've often thought about getting into a sailboat. There is one large problem with this. I stand 6'4" and also have a bad back. That means being crammed into a low head room boat is not a good thing.
We have examined a number of boats at Sail America in Philly, and racers are off the list. As a matter of fact, anything without a full keel probably is also. I don't want to have to dive the boat because the rudder is fouled with weeds holding us back.
If I could put a dollar figure on what we could spend (don't tell the S.O.) I'd put it around 150 to 200K. Since the ICW is a requirement the mast cannot exceed, say 60 feet.
So what brand of boats would be a reasonable starting point leaning towards the head room aspect?
Thanks and Regards
Dan
So anyway,
Thanks and Regards
Dan
