After much research and consternation I decided on a new prop this past winter.
Mechanical vs. Fixed:
As much as I would have liked a feathering prop, Max-Prop was my choice, I decided against it after speaking at length with my local prop shop and a few friends at boat yards. With the tides in Maine we get lots of floating debris, floating line and lobster pots. As was stated to me by more than one prop shop, and numerous Maine boat yard techs, the mechanical props are just not as reliable when you hit something. This happens in Maine and has happened to a couple of my own customers.. This is not to say they are not durable but when I was staring at a four year old mechanical prop overhaul, on the bench at my local shop, for "$900.00-$1000.00", it made the financial part of the decision that much easier.
The minimal drag of a feathering prop would be welcomed but I don't race my own boat so 3-6 seconds per mile lost out to cost, durability, simplicity and reliability. Folders were not even considered this time around and because I have already owned them in the past it was easy to rule them out this time.
Two blades vs. three:
For me this one is easy. Over the years I have had numerous two blade props and have never found one I liked. When I want to use my motor I want a real motor not the feel of an electric trolling motor.
With the tidal currents in Maine and the lack of summer winds we often see, having a smooth well balanced three blade prop is a must for us.
I am not one who is afraid to fire up the Japanese genny when the wind dips below 5 knots, especially with an antsy toddler who's ready for some island exploring etc... We also like to venture up some of our many rivers which can have massive currents. Two blade props have never given me a feeling of total confidence, with a small aux motor, in battling head on with these currents.
Which Fixed Prop?:
After lots of talks with customers, & trial use on actual boats, I decided on a Campbell Sailor Prop ("CS" from here forth). I had read many, many, many prop reviews & discussions using the search tool on about 20+ sailing forums, from SBO to SCCA to SailNet, and every one in-between. One thing I noticed was that I had not read much if any negative comments about the CS, other than sizing issues.. So the Campbell Sailor three blade it was.
Ordering:
After consulting with Norm at West By North, the makers of the Campbell Sailor. I ordered a 16"X10X1" RH prop. The prop took about three to four weeks for delivery which was fine due to my off season planning.
Sizing:
Contrary to popular beliefs and misconceptions prop sizing is NOT an exact science. In order to hit max RPM and size the prop to do that without going over or under by much is not easy and often takes two or more attempts to get it spot on. I can remember working with my old friend Brian, a marine surveyor, who always checked the prop sizing against max rated RPM. We found that close to half the boats had the wrong size prop.
The CS prop isvery efficient. Norm spec'd mine at 16" diameter X a 10 pitch. I was skeptical at first because my three blade Michigan Wheel was a 16" X 12 pitch which is a lot more aggressive. I could not understand how, with loosing so much surface area, I could also reduce pitch? Norm used the Michigan Wheel prop size calculator, which he tweaks for the CS prop design, and decided on the 16X10. Unfortunately when I got the 16X10 it was still over-propped and I was under max rated RPM by about 300 RPM. Not good.. Over propping your engine is not a good idea, and will even void a warranty, so I wanted to fix this as soon as possible.
Once I discovered the 16X10 was still to aggressive, despite the blade surface area being much smaller than the Michigan Wheel, I called Norm. Norm decided to drop the pitch to a 9 and remove some of the cupping on the trailing edge of the CS props blade. Norm's rational was 1" of pitch for a 200 +/- reduction in RPM then some reduced cupping for another 50 +/- RPM. Again, this is not an exact science.
The customer service Norm provides is very good. He actually sent me a brand new replacement prop ahead of time so I could literally change out my prop, with the boat still in the slings, and then send the used 16X10 prop back. The 16X9 prop worked flawlessly and I am now within 30-50 RPM of max rated with a clean bottom and prop.
If you've been paying attention the Campbell Sailor is a full 3 increments of pitch smaller than the Michigan Wheel prop and has far less surface area for less drag through the water. Efficient does not even begin to describe this props unique design. Pitch is basically the theoretical travel a prop makes in one revolution. For example a 10 pitch will theoretically travel 10" in one full revolution provided there is no "slip", but there is almost always slip..
Vibration / Smoothness:
This prop has proven to be the smoothest prop I have ever used or owned on a sailboat. The drive train exhibits no vibration throughout the entire RPM range even at WOT. My Michigan Wheel was tuned and balanced less than one year ago and still could not compete with the smoothness of the CS even on a brand new shaft.
Prop Walk:
Despite the aggressive design of the CS blades the prop displays less prop walk than did the Michigan Wheel. I can not say it has none, but it is about 60% better than the fixed three blade Michigan was.
Drag:
As some of you may know I conducted my own little prop drag study. The results were rather eye opening. The CS prop has about 13 pounds real of drag at about 4.2-4.4 knots while the three blade Michigan Wheel had about 39 pounds of drag at only 4-4.2 knots. For those of you doing the math that is roughly a 200% increase of drag for the Michigan 16X12 than for the CS 16X10. Yes, this is still more drag than a Max-Prop but nowhere near the drag of the Michigan Wheel..
Speed:
I have always run my boat to put the stern wave right at point where my the hull sides and transom meet but without the water climbing up the transom. This puts me at about 6.6-6.8 knots. I used to be at 2400 RPM to do this with the 16X12 Michigan Wheel and am now consistently at about 2250 to do the exact same thing with the CS 16X9. Both props would hit a WOT max rated throttle of 3000 RPM within +/- 30 RPM.
Fuel Use:
I could not decipher any real measurable difference in fuel consumption perhaps because we also have engine driven refrigeration which tends wreck the mathematics of measuring fuel consumption for moving the vessel through the water.
Conclusion:
If you are looking for a rugged, reliable, smooth and efficient fixed three blade prop with less drag than the typical Michigan Wheels, that come standard on most boats, then the Campbell Sailor certainly fits the bill.
While slightly more expensive than a Michigan Wheel it is certainly considerably less than any of the feathering or folders. I think i paid about $540.00 delivered but I'll need to find my credit card statement to be sure..
I waited until I had nearly a full season of use to post this so it could be more accurate and less impulsive. I find if I write something shortly after I buy it I can be admittedly little more biased, in a pro fashion, towards it, then if I wait and use it more. After nearly a full season of use I find I like it even more now than when I initially bought it, perhaps due to the sizing mishap.
Here's cross sectional comparison of the props unique design comparing the CS to the MW:
Here's a photo of the sheer reduction in surface are which helps result in the 200% reduction in drag between the MW and the CS (13 pounds vs. 39 pounds):
Which Fixed Prop?:
Ordering:
Sizing:
Prop Walk:
Drag:
Speed:
Fuel Use:
Conclusion:
