Do you cover your sailboat for the winter?
cromer
Jul 22, 2009
29
Pearson 39-2 Clinton River
How do you cover you sailboat for the winter? Mast up or down? Do you shrinkwrap, use tarps, or use a custom cover? Indoor or outdoor? Do you just leave it uncovered? I'm trying to decide what to do with a Catalina 30 for the winter if I purchase it. I'm not an owner yet. Location: Michigan.
G
Guest
Winter
No. We cruise year around here in the PNW and keep the boat in the water ready to go.
Terry Cox
11,756
Where are you? Are you in a snow belt? That will determine the need for a cover more than anything..
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Long term, if you have to store on the hard, the best bet is to buy a custom winter cover. My 30' boat has a Fairclough Boom tent, which was about $1400. A boom tent, as it sounds, is deployed with the mast up. There is a slightly better design than Fairclough, which covers the toe rail. Mine doesn't and the cover can sag with a significant snow-load, as we had last year. Still, it probably would have given my usual tarp and frame system a run for its money too and I only got up on her and shoveled her off once and she was fine. Shrink wrapping at $300-500/year means the ROI on the cover is reasonable, plus it adds value to the boat if you sell later.
They also make complete covers that come down to the water line for about $2000. If I had to buy one new now, I'd probably buy a boom tent again, but one that covers my toe rails, just for ease of deployment. My friend has the full cover and says its no problem to deploy, but he has a smaller boat (freedom 28).
The other options are to build a frame and use large tarps, which is simpler than it sounds...say $200 the first season. A good tip if you want to use PVC for a frame is to contact a local well company. Up here they are replacing PVC well piping with continuous lengths and getting rid of the PVC is a problem for them. It is a good way to potentially get a few hundred feet of 1.5 inch PVC for free.
There are often groups of friends who get together to buy a good shrinkwrapping gun for joint fall shrinkwrapping parties. That is another way to go. If I recall, a gun is about $300, and buying one might be a way to make new friends!
7,667
Alden 50 Sarasota, Florida
Where are you? In a snow belt? That will determine the need more than anything..
"I'm not an owner yet. Location: Michigan".
As he indicated, he is in Michigan.
given the location, cover the boat. How you do so is a matter of budget but it is essential you keel ice/snow from damaging the boat.
11,756
Don,
The location was added after I asked the question about it. Now that we know the location I agree with you 100% that it should be covered.
What to cover it with will be dictated by budget constraints and preference.
Oct 13, 2007
179
Hunter 37.5 Plattsburgh
My boat is kept outdoors with the mast stepped. I have a custom cover that came with the boat. I know that they are rather expensive,but given the price of shrink wrap for a few years,it will pay for itself after awhile.
Located in far northern NY syate,a cover is a must to keep snow and ice off. I leave 2 hatches cracked open all winter under the cove with all cushions onboard. I have had no mildew or dampness problems at all so far.
MrBee
Dec 30, 2008
425
Irwin 34 Citation Middle River, Md.
Blue tarps at Harbor Freight are cheap enough to buy new every year if needed. Guess it depends on budget and needs and opinion,,,and on Want verses NEED.
Are you gonna cover a $50,000.00 boat or a $5,000.oo boat ?
I will be covering with a few blue tarps. nothing special, just want to keep the snow and ice of the deck. and I make a boom tent to allow room for me to get in and out and do some work inside over the winter. and maybe stay over a night or two....just to remind me why I don't camp in the winter..
Brian
Oct 13, 2007
179
Blue tarps are ok and cheap to buy new each year. I have used them a few years ago once or twice. In my opinion though, if you go this route,you have to check the boat often to be sure they have not ripped off in the wind or that you have a ton of snow and ice on the deck from a rip.
I know that price is certainly a factor for all of us, however, I feel if you have a a 30,000 or more investment it deserves more than a $30.00 blue plastic tarp to keep it's value over the winter.
Sep 19, 2006
643
SCHOCK santana27' lake pleasant,az
first of all we only have two seasons here , spring and damn hot. nine months of one and three months if the other so covering the boat is for heat releaf in the summer or we sail at night and love it
Jun 16, 2009
32
Hunter 30 Behind the house...
being in southern Virginia we keep her in the water all year long but I know that in northern Germany (which has a comparable climate to Michigan, OK even northern Germany is warmer) most ppl houl their boats each winter and try to find affordable indoor storage on the ohter hand in the Netherlands a lot of ppl simply use a bubbler and keep their boats in the water all yhear around
but as mentioned before it is a question of cost or rather boat value
Oct 20, 2008
142
Oday 222 USA
I store my 22 foot boat outside in Minnesota (mast down). Mast is secured horizontally on top of boat from pulpit to stern post and inexpensive tarps are draped over the sleeping mast. I use a lot of bungee cords and duct tape to make sure the tarp is taunt so it is less likely to flog and damage the gelcoat. As added security and/ or should the tarp tear, I secure a 4x8 foot sheet of treated plywood angled and resting high at the cabin top and low on the transom (foam sandwiched between plywood and boat to protect the gelcoat). This way- any snow load that got through the tarps could slide (or be pushed) out of the cabin area.
Any residual water remaining after the water tank has been emptied (potable water tubing and hand pump) is blown out with compressed air. I close all the seacocks, use corks to plug the through hulls from the outside and place laundry dryer sheets throughout the boat and especially in any smaller compartments (under-seating compartments, lazarette, storage, bilge, et al.) to keep any "hitchhikers" (mice et. al) away. We get a lot of high wind and snow in Minnesota and this storage system has worked well for me with no problems. The mast ridge tent is quite steep. I check it often and have never seen any snow accumulate on the tent.
Ducati
Nov 19, 2008
380
Boatless Boatless Annapolis
Always Cover A Boat
I would always cover up a boat because the water turns into ice and that will cause damage
If you are planning on keeping the boat for 10+ years then buy a cover. 10 years or shrink wrapping = the cost of a cover. If the boat is a short term thing then build a cheap wood frame and cover it with a plastic tarp from Home depot. Depending on the size of your boat that will cost about 1/3 that of shrink wrapping.
Once closed in, remember to slightly open all of the ports / companion way so any moisture down below has a place to evaporate out. Otherwise you will get mold/mildew.
We got frost last night.
Feb 5, 2009
255
Gloucester 20 Kanawha River, Winfield, WV
I do the same and also remove my spreaders and lifelines to allow the tarp-tent to drape down more evenly and steeply.
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
Use a custom cover if you store outside. Use the boom as a ridge pole and have it made so that it secures below the lifelines and around each stanchion. a good custom cover will last up to 10 years if properly cared for. Shrink wrap is more expensive in the long run and ultimately ends up in a landfill somewhere.
There are many good sources here in Michigan for custom covers. Just ask around your sailing area for referrals.
544
Bristol 43.3 Perth Amboy
Simple Cover
Hi,
I made a simple cover and frame for my Mirage. I bought saw horse kits x 2 and made them so they are equal heights above deck. One is placed just forward of the companionway hatch, the other on the foredeck. I make an a frame aft in the cockpit and forward by the pullpit. I make a ridgepole with 1 x 3s screwed together. The pole is duct taped to the forestay and backstay and mast if it is up and also to the saw horses. I remove the stanchions and lifelines.
Brown tarp over boat and frame. If mast is down, 2 tarps connected together with aperture for mast.
Gary
Mar 3, 2007
29
Oday 23 Atwood Lake Ohio
Hey there !! I live in NE OH, so Yes, I cover my boat with a custom cover that came with it. I bring my O'Day 23 home each winter, for backyard storage, so the mast has to come down. The cover goes over the deck only. One trick I learned, from a magazine article, was to buy a bag of Contractor Garbage Bags (the ones that come in a roll). I stretch the entire bag out over the mast, then open them out (width wise) and duct tape them down around my mast and halyards, and then open two out completely and cover my roller furling unit and the top of the mast also. Hope this helps you, or others, but Yes, if you're in MI, Oh Ya, I'd be covering the boat if possible. And make sure you put mosture absorbers in the interior, or you will have mildew in the spring. The interiors will develope their own atmosphere, with the temp.s rising & falling in the fall, winter, and spring. And finally ........ my previous boat was a Catalina 25 and I covered it also. I went to the local Tractor Supply and bought a 20' X 30' silver / black plastic tarp (used to cover hay bails). I also used 1" plastic pipe and bent them over the mast, and tucked them under the safety lines (and tied them down) ....... they worked as supports for the tarp. It was a real project each fall but it worked for 13 yrs. that I had the boat ! Oh Ya, and big heavy rubber bungie cords, down around and under the boat kept it tight with the weight of the snow. OK, enough from me !! Again, I hope this all helps !!!
Bob Burns = Rascal
992
Oday 25 Gibraltar
Last winter was my first with my boat and it needed a lot of work on the deck and interior so I used the mast as a ridge pole, high enough to get around on the deck and had it shrink wrapped. I had a zippered door installed and plenty of vents. On sunny days with temps in the 40s temps inside were over 70. 70 outside and 100 inside. This winter I'm building a pvc pipe frame that will give me open access to the deck. Two doors, one forward and one aft for better ventilation while working inside. Think of it as a portable boat shop (she's stored on a trailer). This year it'll be white shrink wrap. The blue wrap last winter was a bit much at times while working in it. With the vents the boat had no problems with any condensation or drying anything inside.
Rich
Nov 26, 2008
1,970
Endeavour 42 Cruisin
Shrinkwrap supplies for a 45' sailboat run about $200. Not too hard to do if you have a calm day and a little help. Make sure you add some vents to keep air flowing.
Michigan has a lot of freeze/thaw cycles over the winter. Covering is an excellent idea
Jul 18, 2009
274
marine clipper 21 ft santa ana Southern Lakes,Yukon
i live in snow belt...i put mast down and then lay 2 long wide tarps over mast...the mast give peak effect to shed snow...the tarps overlap 4 ft...and over hang 4 ft each end and hang along the sides at water line...then i just tyvek tape a few rounds around the circumferance
