Welcome aboard Ron. One of my friends has owned an O'Day 20 for quite a few years now and he likes it. He also bought a 1986 O'Day 272 a couple of years ago. I helped him sail up to Bristol RI from Cape Cod Ma. He put it on the mooring and used it a couple of times. For two years in a row, he has put his O'Day 20 on the mooring. Sometimes, bigger isn't always better. Good luck with the O'Day 20. Myself, I'm a small boat sailor and I'm staying that way.I just bought an O'Day 20 1974. I'm looking for other owners of a 1974 O'Day 20. I have many questions about the boat. I will be trailering the boat. Thank you very much for your help. RonC
Ron,Hi Joe
This is as big as I want to go. I want to stay a trailer sailer.
RonC
Keep your eyes open for a good club in your area where you can have access to a good ramp and plenty of live docking for loading and unloading. Boatyards and private marinas aren't really the answer. I found that out a couple of years ago the hard way. When I first joined the club back in 1995, I was able to leave my boat sitting on the trailer with the mast up on club property, and use it whenever I wanted to go sailing. I didn't have bottom paint on the boat back then and I was able to borrow an empty mooring for a few days a week. That gets pretty old after a while. I got tired of having to clean the marine growth of the hull of my boat when I left it in the water too long. Clubs are great if you can find the right one, and you can still trailer to other areas if you like. Good luck with the O'Day 20.sounds great Joe. I think I'd rather moor also because it's getting harder the older you get to set it up but there isn't allot of choices As long as I can sail.
RonC
Hi Jim!Hi Ron and all,
Just joined this forum also, and just recently finished a complete rebuild of my Oday 20. Still have some minor projects, but she is back on the water. We trailer sail all over FL. I would be happy to share pics of the project.
Jim
The boat is a '77, and sat for about 10 years before I found it in March of '08. So "Lazarus" was an appropriate name after completion in December '08. The boat was completely stripped of all interior, wiring plumbing, hardware, bottom paint, and every screw except those holding the deck to the lull. I low pressure sand blasted off 3 coats of bottom paint, and then started the rest of the bodywork on hull and topsides. The gelcoat was too tired to bring back so she got a coat of urethane primer and 3 coats of urethane finish, all after alot of prep. As you guys know its all in the prep.i for one would like to see pictures of the oday 20 rebuild. it looks like a new boat. what year is it?
Thanks Joe, I will share some of my updrade projects as well. Today's project is getting some ventilation forward. The boat when I got it had one of those inverted dog bowl vents (what I call them) and leaked enough to allow some damage to happen to the surrounding deck core. During last year's rebuild I glassed the opening flush until I could get to this project. I recently bought a NOS Lewmar 12x12(10-1/4" r.o.) low profile hatch ($115) at my favorite marine salvage store The Sailors Exchange in St Augustine. IMHO a bigger hatch is not needed here, as the forward deck is so low to the vee birth you cannot climb out of it. I am mounting it so to cut out the old vent location, so I can rid any remaining damage that I could not get to.Hi Jim!
The boat looks great! You did a super job on her. Don't be afraid to do modifications on her. I've done at least 28 mods on my OD 222 through the years. Some of them are posted on this forum under "Owner Directory"-"Owner Photo Album"-"Trinkka." I understand that we're talking about two different models of O'Day sailboats, but there are some good ideas out there that can be adapted to any model sailboat. I like the idea of having Gennie winches with tracks & cars on the combing. My boat wasn't supposed to come through that way. I made that change myself. You probably have no need for a mast raising/lowering Gin Pole for your boat, but maybe you could add a mast holding crutch with a roller in it so that you can slide the mast aft or foreword. Little things like that can really cut the set up time down quite a bit. I use quick release shackles for my main sheet and a press button quick pin on my fore stay. My back stay has a regular turnbuckle and a Johnson Handy-Lock on it. The Handy-Lock is like an adjustable back stay, but I've always used it to throw enough slack in the fore stay to disconnect it for lowering the mast. If you and Ron do a lot of trailering, you may want to consider doing some of these things to your boats. Handy-Locks are very pricey. I bought mine used from a rigger. With that said though, there are probably some other type of lever type adjustable turnbuckles that can work just as well as the handy-Lock. If you have a tip up rudder on your boat, you may want to add a rudder blade pendant line to hold it up. This would allow you to launch the boat at the ramp with the rudder on and tiller tied off in the center. I don't trailer my boat as much as I used to, but I'm glad that I did a lot of these mods years ago because it's really paid off today by saving me a lot of time and prevented a lot of needless work and aggravation. Good luck with your O'Day 20s guys and always remember when you get an attack of "Big Boat-itis", it isn't what we own that makes us happy, it's what we do.
Smooth Sailing!
