Has anybody retrofitted their mainsheet controls so that you can make adjustments without having to leave the wheel while single-handing? I sure would be interested in your solutions. Thanks!
Having had the same problem, I use my winch for gross adjustment of the main sheet, and have added a turning block on the handrail on the cabin top, back to a cam cleat mounted on the aft pulpit for the traveler. This gives pretty good control using the traveler once you get the main set initially, and is easily done from behind the helm.
There is one line on each side regardless of how it is rigged. My traveler lines were long enough that you could do the adjustment from behind the wheel, but getting the traveler to release/lock back in from back there was very difficult (and it's usually when she is loaded up in a puff and the boat starts to round up when you can't get the traveler to release). When I am sailing with a lot of crew, or racing, I can move them back to their normal position, but single handed or with inexperienced crew it is much easier with the modification.for traveler adjustment? Why not just put longer lines on them so they can run back behind the wheel? Would seem to be simpler. Is there only one line then or do they run on both sides?
Like your set up. My mainsheet seems to take off from its clam cleat at the most inopportune moments. Therefore thinking of adding a cam cleat as I had on previous boat where I had to use the mainsheet as the boat needed 'dinghy type' handling in gusts.This is how I solved the problem.
