You're good Tom, very good.IMO wing keels are hard to do well. Very small changes to the geometry can make huge differences in performance. Not all keel shops can get work in tolerances of < 1 degree. But a 1 degree difference in the wing angle at the keel or the twist of the wing can make the whole system very significantly worse. And cruising boats generally sail slower beat less than racing boats and wing keels make up time at speed uphill and lose time off the wind... My general take on it is that a bulb with a low Cd is a better bet for most cruisers.
Just to add some pictures I did a quicky run in XFLR5 of a simple deep keel (1.8 meters) the same keel with winglets and wings and then a shallow longer cord version (1.4 meters) with wings.
View attachment 25013View attachment 25014View attachment 25015View attachment 25016
If you look at the streamlines you can see that the wing has to interact with the tip vortex of the keel in very complicated way and the ideal angle of attack of the winglet changes along it's length for any given speed and angle of attack of the keel... The leeward winglet is pretty much just baggage but you need symmetry so you've got to optimize the winglets with that in mind, too... And the flow is way to complicated to make the computer models believable and robust so you have to go to the tank with all of its problems and .... Well, bottom line, they're hard to design right and hard to make right... But there's probably no real harm in them for cruising -- the losses, if any, will probably be below the threshold of noticability for most -- but I wouldn't pay extra for one either...
I like Ericsons. The one I saw had some issues but I wouldn't want anyone to draw conclusions from a sample of one.
That sounds right. In the case I saw they wanted to add a bilge pump and re-plum the existing pump (which used the head's sink drain). So they had to run pluming from the bilge to the transom and to do that they had to dissemble the port side of the boat from midships aft... Bummer. Also I noted a lot of solid PVC pluming glued to hoses and some of those connections were not readily inspectable and were marginal too. I'm not sure if that was as built or something that happened later -- but it was done with the furniture out...
--Tom.
I see you're from Honolulu, have you ever been to Navatek? They have quite an amazing yard and tons of lift body stuff. I flew there a few years ago to set modify a high speed rib for the Navy. I was amazed at some of their winged bodies, which reduced displacement without lifting the boats out of the water. I couldn't help think they would work on a sailboat.
I agree, some irregular glass issues should not steer someone away from those boats.
I did see one of the PS built boats and it was a very nicely done boat. No complaints or remarks, just clean and crisp.
I would like to add that a wagging keel is not so unusual and can be easily fixed with additional floors. Early J24's are a perfect example of wagging sumps, very easily repaired.
I guess in retrospect, removing the finger pointing, it is safe to say the days of bump and run are over. You hit bottom, you better haul out and get a good survey. Kind of like bumping a new SUV at 3mph, will result in thousands of dollars to repair.
