Crevice corrosion
Tim R.
May 27, 2004
3,626
Keels are not the only thing affected by crevice corrosion. I replaced all the clutches on my cabin top this weekend and here is one that I found with not much bolt left. This was the clutch for my main halyard. The core was rotton so I removed all the wet wood and potted the holes. The new clutches(Lewman D2) are very nice and the admiral loves using them.
274
marine clipper 21 ft santa ana Southern Lakes,Yukon
is never seize a good product that would work to prevent corrosion like that..???...it works well in other application...automotive ,snowmobiles etc..
Bob J.
Apr 14, 2009
775
Sabre 28 NH
Gezz Tim, not much left of that bolt.
Never seize, that's a really good point m8magic, that's gearhead thinking. I used that product on past fishing boats & jeeps.
Bob
Oct 2, 2006
1,517
Jboat J24 commack
If the hardware is bedded correctly it will not allow water to enter and cause the problem
Tim R.
May 27, 2004
3,626
Bingo.
That was a clutch added by the dealer over 20 years ago.
Tim R.
May 27, 2004
3,626
Agreed.
BTW, the bolt was galvonically welded to the aluminum clutch. Lifting the clutch off the deck was easy so the only bond was mechanical and failing.
Jul 18, 2009
274
Agreed.
thats the beauty of never sieze...eliminate galling or welding on applications..yet still allows good mechanical tolerances for fit..
Tim R.
May 27, 2004
3,626
Except that the bolt head was exposed and subject to UV, salt water, dirt. How would Never Seize hold up to those elements?
The new clutch bolts are hidden inside the clutches but still subject to water and dirt. Butyl tape was used around the bolt and chamferred holes to insure a lasting seal and ease of maintenance.
Jul 18, 2009
274
well that clarifies things...:)
