We agree that the design was horrible. I think the design played a significant role in the degree of damage resulting from the grounding and the trecherous nature of the failure mode it set the boat up for later. For Richards not to have pointed this out makes me suspect his impartiality. I might feel differently if I traced all his calculations through but I would be shocked if I could justify that design or overlook its role in the subsequent failure. ...
Of course the design was the major element in how the boat responded to the grounding. Everything from the shape of the canoe body, the built displacement, the fairing of the floors into the topsides and, well, everything were factors. It's a very complex problem made more so by the fact that the initial impact on the keel was off-center on the "T" bulb and there were multiple secondary shocks as they pulled her off. I really don't want to defend the design and I don't have any loyalty to Richards either. But, composite failures are complex and they can occur within the laminate. I don't think there is any way to design around that. If we sail in plastic boats we, as users, have an obligation to be aware of the danger of inter-laminate failures. Take home lesson: if you run aground hard enough so that your hull has a major deformation and so that you can see daylight between the hull and the keel,
have an expert check the entire hull. Richards does point out that the design is for racing and does note that the result was a boat more susceptible to damage.
ISO has a section where you are supposed to work out the additional tensile strength of the forward bolts and the additional sectional modulus for the aft floors needed for grounding. Richards includes the worksheet in his evidence but just eyeballing it from the photos the aft floors don't look to be tall enough or to have sufficient flange area... I suspect that was a design or build error that resulted in excess damage when they grounded.
I understand that you're looking at lessons we can learn looking forward. And, I agree that the design played a big part in the grounding accident damage and the tragic result. However, I still feel that Richards is right to say that absent the grounding and negligent inspection and repair work there is no reason to believe the keel would have failed when it did. I don't feel all that sad that the lawsuit will probably break the builder, but, having skimmed the reports, I think the real lesson is that FRP failures are complex and when there is reason to believe the laminate might be compromised it is critical to life and safety that they be carefully inspected by an expert. IMO, it is T A&M's failure to do that which lead directly to a the death. Their failure to do the right thing at the time and their attempt to cover it up are far more serious crimes, IMO, than Cape Fear's.
Looking forward, it seems to me that as racers demand higher aspect keels that serious thought should be given to attaching them in ways that can absorb more energy before the hull fails and perhaps you're right that more though should be given to making failures evident. Cars have crumple zones and alignment jigs. Perhaps we can borrow some of those ideas...
--Tom.
